Results 1 to 10 of 13
Thread: electric/resistor guru's ... a question
    Oct 2004
    Red face electric/resistor guru's ... a question
    what type of resistor would i use to reduce a 90 watt headlight bulb to say 45 watts?
    i know it's kind of offtopic, but i've been searching day and night and haven't been able to find anything
    . The guys at radioshack didn't even know what a resistor did.
    thanks much
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    you want to reduce the wattage of the lightbulb?
    -Mars
    Oct 2004
    You will use a power resistor, and calculate the value using some standard electronics formulas:
    This has been edited and does confirm Nic's data (thanks Nic!):
    To determine equilivent resistance of lightbulb:
    Power = (voltage * voltage) / resistance
    therefore
    resistance = (voltage * voltage) / Power
    which gives me
    resistance = (12 * 12) / 90 = 1.6 ohms
    Now, to drop the power dissapated by the light bulb and the current consumption, put a resistor in series with the light bulb. To calculate, use the following:
    current = sqrt( power wanted / resistance of bulb) =
    current = sqrt( 45watts / 1.6ohms) = 5.3amps
    Now, total resistance = total voltage / current =
    which gives me:
    resistor + 1.6 = 12v / 5.3amps -> resistor = (12 / 5.3) - 1.6 = .664ohms
    Power of resistor:
    Power = current * current * resistor =
    power = 5.3 * 5.3 * .664 = 18.65 watts
    NOW, a 20 watt resistor is still kinda big, so it would be better to use multipe 10 watt resistors. 6 4ohm 10watt resistors in parallel will give you 0.667 ohm and 60 watts of power handeling, which should work. (To calculate other parallel resistances, use the formula:
    resistance of paralled resistors = 1 / [(1 / resistor) * number of resistors in parallel]
    power of paralled resistors = power of resistor * number of resistors in parallel
    However, I don't know that this will all work the way you are thinking. The color of the light will likely change, it will be much dimmer, etc.
    What are you trying to do? Dim the bulb? Why?
    The above has been edited and corrected, as my previous calculations were flawed as Nic graciously pointed out.
    ColdPhreze
    14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
    200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
    2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
    Das
    Das is offline
    Constant Bitrate Das's Avatar
    Aug 2004
    Texas
    Would it be feasible to make your own power supply? Seeing as hower the power supplied to a car is already DC? Whats not to say you make your own. This is a new concept! to me... Has anyone ever attempted anything/seen anything like this?
    Hrm my truck runs @ 12 volts with a 105A alternator..
    Oct 2004
    Das, what exactly do you mean by make your own power supply? How does this have refrence to this thread? Slightly confused by your question. If you are referrring to making a DC-DC power supply for a carpc, then goto www.mastero.tk. It's a DIY carpc power supply for pcs.
    ColdPhreze
    Oct 2004
    Re
    Coldphreze, thank you so much!
    To answer your questions, yes I want to dim the light bulb. Why? Because I have a motorcycle that runs 1 headlight during the day and it looks like the other one is out, when in actuality it's for high beam. To offset this, I am going to use a yellow light bulb on the high beam but at a lower wattage (so I don't blind people, like you all )
    Oct 2004
    So just to clarify, I go to RadioShack and purchase (9) 15ohm 10watt resistors and solder those to the power line of the bulb (it has 1 ground and 1 positive)? Thanks!
    Variable Bitrate Superduck's Avatar
    Oct 2003
    Vancouver BC
    Is it a CBR by chance? The manager at my work has an F4i and was complaining about the same thing. I think he installed a couple of white LED's inside the the housing, so he didn't have to mess with the high beam.
    Anyway, I guess you're going to run an extra wire to the high beam, so you'll still be able to use it as a high beam? I'm thinking you'll be glad you did if you're on a dark road at night.
    Doesn't anyone make a replacement housing that's got a high/low on that side, so you can switch it?
    Cheers,
    Kris
    How Much Horsepower Can I have And Still Go To Heaven?
    Oct 2004
    That is correct. Also, those resistors can go on either side of the bulb:
    power from bike-----/\/\/\/Resistors-----Light(+) Light(-)-----ground
    or
    power from bike-----Light(+) Light(-)----/\/\/\/Resistors-----ground
    Just for all you perfectionists, please realize I know halogen and most other lights don't have a positive and negative side, I am simply referring to how it is wired in the bike, which side the positive line comes in and which side of the light is connected to ground.
    ColdPhreze
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Quote Originally Posted by ColdPhreze
    therefore
    which gives me
    resistor = [(volts * volts) / power] - above calculated resistance of light bulb
    so you get:
    resistor = (12 * 12 / power you want the light to dissapate) - 1.6 = 1.6ohms
    NOW, a 45 watt resistor is HUGH, so it would be better to use multipe 10 watt resistors. 9 15ohm 10watt resistors in parallel will give you 1.667 ohm and 90 watts of power handeling, which should work. (To calculate other parallel resistances, use the formula:
    ColdPhreze
    if you add a 1.6 ohm resistor, the 2 resistors put together (one being the light globe) will use 45watts, both resistors being equal means that they each are using 22.5watts each, so you are efectivley reducing the power output of the light globe to 22.5 watts and dissapating 22.5 watts in the resistor
    Signature: [==||========] 20% complete
  1. little question ive pondered..
    By John Crowe in forum Newbie
    Last Post: 04-06-2005, 05:09 AM
  2. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 05:26 PM
  3. wirering question...
    By Pingo1969 in forum Power Supplies
    Last Post: 04-15-2004, 04:39 PM
  4. question about ripping apart lcd screen
    By FALLENNITE in forum LCD/Display
    Last Post: 01-21-2003, 07:55 PM
  5. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 01:27 PM
