Results 1 to 4 of 4
Thread: PW-60 ... regulation?
    Nov 2004
    Okay, I bought a PW-60 to run my EPIA-5000 board in the car. I use an Optibase MPEG2 decoder PCI card. System reboots and otherwise is unstable.
    Much reading shows me that maybe I was misled by the people selling it. They indicated it would run the older slower boards (like I have) with no problems in a car, and as long as the DC voltages weren't way out of wack, it would power 1 3.5" drive. Planned accessories is pretty much limited to two wireless modules via USB.
    So now I'm seeing I need to regulate the DC voltage before it hits the PW-60.
    I think 7812's (or 7912's, the +12 version) require too much power inbound to work. What are people using?
    I plan to jumper the power jumper on the system board, and tie the thing to the ignition lead. Either that, or make a circuit that powers the computer up the first time the remote line from the stereo goes active, but doesn't collapse until the car is turned off.
    I've toyed with the idea of just leaving the computer running all of the time. Anyone do this? Maybe add a cap for starting the car?
    I'm also getting a ton of noise (interference from the hard drive of all things) on the console RCA output. The 2nd RCA + stereo outputs from the Optibase card work fine. I have a LCD up front that has two composite inputs, one tied to the console output. Then the 2nd output from that LCD + the two headrest LCDs are hooked to a mobile video amp, hooked to a Sony XT-40V TV module, which is hooked to the computer (plus stereo).
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    Nov 2004
    What about...
    I was thinking about getting the $65 setup that has the solid chunk regulator and the external power supply board (Moxie? I forget the name, Moxsomething).
    Anyways, for the time being I'm going on a trip from Virginia Beach to Flordia, and I would like to be able to run the setup on my way. I am thinking about putting a heatsinked LM317T setup for 12vdc before the PW-60.
    Will this be enough to regulate the PSU to run the thing? Motherboard, Optibase PCI card, and 3.5" 20GB disk?
    I realize this will only work if car is running and output is above 13vdc.
    Aug 2004
    California
    Don't know how much current the LM317 can push. Check its datasheets (And remember, watts = volts * amps).
    The M-something supply you're thinking of is the Morex.
  1. Replies: 36
    Last Post: 07-05-2006, 11:10 AM
  2. 12V regulation for PW-70a
    By Shaky in forum Power Supplies
    Last Post: 10-28-2004, 12:54 AM
  3. ITPS Regulation
    By NewTechFool in forum Power Supplies
    Last Post: 07-10-2004, 06:50 AM
  4. Starvision Power Regulation?
    By sq_geek in forum LCD/Display
    Last Post: 06-05-2004, 09:04 PM
  5. Got my PW 60 today
    By eugenen in forum Power Supplies
    Last Post: 05-13-2003, 09:08 AM
