Have you attached to the mobo properly. What are you trying to run ?Originally Posted by jermaine
Finally my opus arrived.
I connected in my car but my computer doesn't start.
I see a green light flashing on the opus,does somebody knows what it means?
I connected the three wires of the opus,but the computer won't start
annybody suggestions?
regards
a simply via 800 mhz,not a big deal,but it won't start.
I think you can't do much wrong,isn't?
I don't know exactly what you got, but is it EPIA V8000?Originally Posted by jermaine
If so, check this thread.
There seems to be an issue with OPUS and V8000
where can I see wich model I have,I only know it has a 800 mhz proccesor
I have ordered today this one,will I have teh same problems with this motherboard VIA ME6000 CLE266+600 LVSX??
hmm, the blinking green light indicates that the OPUS has power but is in its idle state (comp not on). did you make sure to attach the 2-pin motherboard cable in the right place?
90% done - Sempron 64 2600+, MSI RS480M, 512mb, 80gb hd, 7" Lilliput, 802.11g pci, Itrek gps, Panasonic slim slot DVD/CDRW (broke :( ), Hauppage Wintv, Iguidance 2.0, Opus 150w, Griffin Powermate, Optima Yellowtop, Infiniti 6002i & 9603i
My Install
that's one thing I am not sure about,does somebody have the manual of the epia motherboard or a link
thanxx for your help anyway
Not only does it have to be in the right place, it also has to be the right way roundOriginally Posted by bulgogi777
If it doesn't work, try turning the cable the other way round![]()
Co-Developer of A.I.M.E.E
www.aimee.cc
I am sure the cables are in the right position.
but still it won't start,maybe motherboard is dead.
does somebody knows the meaning of blinking the green led?
