Results 1 to 7 of 7
Thread: Too many amps (question fo you electrical people).
    Jun 2004
    I've had my car computer running for over a year then one morning, completely randomly the inverter goes into protection mode and won't supply power to my computer. I checked the voltage between the terminals and found it to be about 12.15 volts. I was unable to check the amps running through the cables but it is definitely too high because the inverter goes into protection mode. I've also tried a different inverter with the same outcome. I've tried switching the grounding position with no luck. I'm completely stumped. I just have no idea why it would randomly do this. Any of you electrical wizzes know what the problem might be?
    Thanks.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    have you checked the fuse on the inverter?
    xtm
    xtm is offline
    Oct 2004
    Use Search, NJ
    Quote Originally Posted by Telos
    One possible cause is that your computer's power supply might be shot. Try your inverter on a different power supply and see if it works.
    CarPC Status: 0%[••••••••••••---]100%
    Smashed 4" Lilliput
    66 Mhz Pentium Pro
    400MB Ultra 33 IDE HD
    EISA VGA card (16 colors)
    Windows 3.1
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Have you tried turning on the inverter without a load. As xtm said, it could be your PSU.
    bakersfield, ca
    whats the voltage coming from your alt? alt might be dying maybe battery. when voltage drops amps increase causing heat and fuses to blow.
    Jun 2004
    This happens with or without a load on the inverter. The fuse on the inverter is fine as it powers up and is running but will not supply any power to anything. As stated before there is a voltafe of 12.15 volts from the battery, which is only 2 weeks old. I'm really stumped on this one. Anyone else have an idea?
    IMHO, there are only a few possibilities:
    1. the inverter is simply bad.
    2. there are loose connections to the inverter (check all power wire connections, both sides of the wires and positive and negative wires), which would severly limit the current to the inverter, causing the low voltage alarm to come on
    3. The fuse Looks fine, but in reality is damaged. People with OPUS power supplies have experienced this occasionally. Try replacing it with a brand new one.
    KyferEz
  1. curcuit question for all electrically knowledgable people....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-17-2004, 09:51 AM
  2. Connecting wires to switch, dumb electrical question
    By bombboyer in forum General Hardware Discussion
    Last Post: 01-07-2003, 08:13 AM
  3. Case question, electrical boxes?
    By Duphus in forum General Hardware Discussion
    Last Post: 09-15-2002, 07:00 PM
  4. Wow you people are fast! LCD Question
    By Strix in forum LCD/Display
    Last Post: 06-28-2002, 12:18 PM
  5. electrical question
    By cruzc_99 in forum Off Topic
    Last Post: 12-10-2001, 07:37 PM
