I decided to get a usb hub to solve the problem of usb always having power with my opus 150w. I hooked up the hub and cut the red wire in the usb input to prevent the computer from powering the devices and now the computer does not see any of the devices. (yes the hub has power from an inverter)
also, I think I will move the hubs power from the inverter to the opus' 5v line if it will work....
Also do you think it might work out if I connect the hub, my external dvd drive and a wireless mouse charger? they all run on about 5v i think...
EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
My Truckputer
yes the power light works when i apply power to it after I cut the red wire which I believe is the power wire.
