Results 1 to 7 of 7
Thread: recommend a PSU for me, please
    Jun 2004
    I have a M10000 with 5400 rpm notebook drive, dvd rom, sound output, and it will power a mouse gps and maybe a usb network card.
    My goal is to have the carputer startup with the ignition and then shut off after i turn the car off after a minute or 2
    I have tried reading as much as possible, i know the pw-70a is for these small pc's, but then i read everyone puching the bigger opus supples. I'm pretty sure I need an ITPS for the startup/shutdown procedure. Does the bigger OPUS power supplies have them built in? It just seems there is confusing information on what is recommended.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    I would not recommend an ITPS...if you want to go the PW-70 route then I'd get a carnetix to regulate the power for it. For your set up an Opus 90W would be perfect, or if you think you may upgrade to more components or a more powerful system later and size isn't an issue get a 150W.
    Quote Originally Posted by tjb1231
    Get an opus 150w, it does everything you need: will provide enough power, startup and shutdown (no need for ITPS), and monitor the battery to make sure that you are flattening it
    Also it will allow you to upgrade your components easily to something like a P4 board.
    Aug 1999
    Washington D.C.
    The OPUS 90 watt would work well with this setup. http://www.mp3car.com/store/product_...products_id=30
    FLAC jbors's Avatar
    Nov 2003
    Not sure why would you need more power for the config like yours. Simple math shows ~40W, which is fine with ITPS/PW-70. You don't even need 70A which is more expensive.
    ITPS can feed up to 170W, but they recommend 72W max @17V.
    Car pc integration with ease
    Car mediacenter
    Oct 2004
    I know I'm going to get flamed for this...
    My brother uses a Casetronic Mini ITX 2699R which comes with a 60 watt psu. Now, it says 12v DC input, however, if you look at the AC power brick, it says 12-14 volts output @ 5amps. That doesn't seem very regulated to me, so we decided it should be safe to directly connect the PC up to the car's battery.
    His car outputs 14.1volts while running. He has been using this setup for 4 months now, no problems. I don't gaurantee you won't have problems, but he doesn't so far. And he uses a separate startup shutdown power controller to handle the turning on and off of the PC.
    ColdPhreze
    14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
    200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
    2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
    Jun 2004
    So the Opus have built in controlers for starting up and shutting down the computer with the ignition of the car?
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 12:04 PM
  3. hooking up my arise PSU....?
    By jusatry in forum General Hardware Discussion
    Last Post: 03-13-2004, 08:53 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  5. mircoATX PSU?
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 03-12-2001, 03:30 AM
