Results 1 to 8 of 8
Thread: 12v sony ps2 power supplies?
    Nov 2004
    I found some 12v supplies for the older ps2 but any solutions for the new, thin ps2?
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    where did you find them? my old PS2 takes a cable that goes straight form 110V to it... and then it has a internal power supply which converts it to whatever it needs...
    so basically in the car i am stuck using a inverter for it...
    Nov 2004
    Cali
    The new thing PS2 takes 8.5V DC.... that might help you in your search, although I am sure there isn't any kind of purpose built adaptor, at least not yet.
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    Quote Originally Posted by rushnrockt
    Well now we know the voltage, and finding the max current draw should be nice and easy: just look at the label on the thing.
    Then go look for an 8.5V voltage regulator that gives you enough current, and use that Will this work?
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
    Nov 2004
    Cali
    You need 4.3Amps. Not sure if what you found there is exactly the kind of thing zombie was looking for, doesn't seem very car pluggable
    Nov 2004
    Yah you're right... I think i'll just get an inverter for now.
    May 2007
    if you take apart the ps2 there is a small power cicuit on the bottom side. remove that and there will be 4 little prongs that plug into the circuit board you just removed you can the two closest to the inside of the ps2 and tie them together and wire a jumper from there to ground and the two closest to the outside to +12vdc. If you really want it to look facotry then take apart the switch and run your jumpers to that and cut the end of your power cable off and now you have a ps2 that runs of off 12v.
    Nov 2007
    http://www.mod-chip.com/en/pstwo_car_adapter.php
  1. Sony cdx-505rf power wiring setup?```
    By deathrow in forum Car Audio
    Last Post: 05-02-2004, 10:25 AM
  2. Shuttle PC and Power supplies
    By SteveC in forum Newbie
    Last Post: 04-20-2004, 12:32 AM
  3. Where do I look for Inverters/ DC-DC power supplies...
    By MobileSuit in forum Power Supplies
    Last Post: 11-17-2002, 02:59 PM
  4. DC-DC power supplies
    By packwolf in forum Power Supplies
    Last Post: 06-17-2001, 03:05 AM
  5. How do i make -8V from 12V power?
    By helloman in forum Power Supplies
    Last Post: 04-26-2001, 01:33 PM
