Results 1 to 10 of 11
Thread: Advice Needed... Inverter with ITPS?
    Nov 2004
    Calgary, Canada
    Hi all,
    I am fairly new to this scene, but I am a software developer and have been building PCs since '90. The only thing that I am not that good at is electrical (fraknly, it makes me a bit nervous)...
    I have been reading here for a few weeks and am wondering if it would be recommended to have a 300W inverter power my CarPC with an ITPS shutdown/bootup controller in the mix (obviously to control the shutdown and startup procedures)
    Would this work??? Or do I need a DC/DC power supply like an Opus?
    Thanks.
    Nov 2004
    Calgary, Canada
    anyone????
    Constant Bitrate dingofarmer's Avatar
    Oct 2004
    colorado
    I use an invertor, but I also have a laptop, No auto shutdown/startup/cold start.
    ITPS has it ,but alot of guys have gone to the opus.
    Invertor is not bad, but most will not survive a engine crank, so when you have to get gas or something, you would have to hibernate/shutdown, which can get old real quick.
    Nov 2004
    Thumbs up
    hi, i have ordered an itps after about 6 months of having a carpc and using an 100W inverter powered through cigarette lighter. was gettin sick of this cos was gettin a lot of blown fuses. anyway i thought that the point of the itps is that you no longer need an inverter. the itps connects to a car power wire and the other end goes onto the psu of the pc and the atx connecter onto the atx connection on motherboard.
    btw great forum, only found out about it yesterday :s
    Low Bitrate jadz's Avatar
    Most would agree that the Opus is a good solution.
    There would be no issue using the ITPS to both turn on and off the power to the inverter, and also to send on/off signals to the MB.
    Code:
    +12V---->ITPS---->Inverter---->Standard PS---->PC
              |------------------------------------->PC On/Off Switch
    note you will likly want to bypass the 12V regulation of the ITPS if you are using an inverter.
    Most people (myself included) do the following
    Code:
    +12V---->ITPS---->DC-DC PS---->PC
    Nov 2004
    i thought the point of the itps was that you didn't need an inverter?
    car --> itps --> pc psu
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by sini
    i thought the point of the itps was that you didn't need an invertor?
    Depends on what PSU you're using...
    Code:
    +12V---->ITPS---->Inverter---->Standard PSU---->PC
    You do not need an inverter if you have a DC to DC power supply like the 70A. You do need an inverter if you use a standard household power supply.
    Nov 2004
    yep, agreed. sorry i forgot that there is another converter between mr. inverter and mr.pc on my setup therefore my psu is dc to dc.
    May 2004
    NJ
    $inverter + $ITPS + $Time + $Headache > $OPUS
    Enough said!
  1. Advice Needed
    By EBFoxbat in forum Car Audio
    Last Post: 11-22-2004, 10:05 AM
  2. ITPS Needed?
    By Jeremyvnc in forum Power Supplies
    Last Post: 09-01-2004, 10:38 PM
  3. Help needed on switch install for Inverter
    By eazyrog in forum Power Supplies
    Last Post: 07-24-2004, 07:42 AM
  4. Inverter + ITPS
    By masher in forum Power Supplies
    Last Post: 05-28-2004, 03:09 AM
  5. My project for the day - advice needed
    By ddt in forum General MP3Car Discussion
    Last Post: 12-02-2002, 08:51 AM
