Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: Powering PC With Power Button Instead of Automatic Power
  1. #31
    Apr 2001
    Portland OR
    I made a list of the ways you can connect the uSDC20D to solve this problem. I don't know if the OPUS works the same way..
    MPEGBOX - Plexiglass Computer
  2. #32
    Variable Bitrate HummDinger's Avatar
    Aug 2004
    Milwaukee, WI
    Use a toggle switch mounted in the front of your car (momentary on) connected to your power switch on the PC. Then run a line from the 12 volt power connector inside your PC, and connect this to a relay to toggle the constant power supply (directly from battery, use an inline fuse). Then connect your accessory power lead after the relay. This will allow power to the computer for startup (when key is in accessory position or run position). But after you turn off the car, press your toggle button in the front of the car which will allow the computer to shutdown. After the computer shutsdown, it will open the 12v circuit on the constant power line. Killing all power to your computer (also usefull if you use an inverter)
    Thus giving you a cheap shutdown controller.... BTW this was discussed in the forums once before. But this is a good refresher.
    You can still have something if you have nothing
  3. #33
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    Legend, it will work on any car.
    Zootjeff and HummDinger, the Opus already has a SDC.
  4. #34
    Jun 2004
    Thoughts on setting up a rocker switch to do the following?
    ON to set mobo/opus 150 in standby mode
    Off to manually turn off the PC when I want
    3rd position to hard shut down my PC and power (cutt power to opus)
    I want to be able to shut down the power to everything for those times that my PC is going to be sitting overnight. But I want to be able to use standby throughout the day. should I just set the opus/mobo to standby and just manually shutdown the PC when I want to?
  5. #35
    Would this work for me?
    My problem is I have the OPUS set to shutdown after 10 seconds, but like when im getting gas. i dont want the computer turning off and turning back on.
    So can I replace my accessory wire that goes into the opus with a constant power wire instead with a toggle swtich hooked in the middle of that power wire.
    That way when I want to PC on, (whether the actual car is on or not) I can just flip the switch and the OPUS will see the constant power on the accessory wire and start the computer. And even when I shut the car off, the OPUS will stay on because since the accessory wire is actually a constant wire, the OPUS will think the PC is on still.
    Is this right?
  6. #36
    Mar 2008
    Best Solution To Your Problem
    this attaches right to your motherboard
  1. Remote PC Power Switch
    By Terran in forum General Hardware Discussion
    Last Post: 01-06-2005, 08:13 PM
  2. I want to add a power button on my dash. Which can i use?
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 10-25-2004, 03:17 PM
  3. power button
    By EggrollXpress61 in forum General Hardware Discussion
    Last Post: 08-14-2004, 04:26 AM
  4. emulate power button in windows?
    By kami333 in forum Software & Software Development
    Last Post: 12-22-2003, 02:12 AM
  5. Have to switch inverter off and on to power up pc
    By mbowler in forum General Hardware Discussion
    Last Post: 08-21-2000, 11:00 PM
