Results 1 to 6 of 6
Thread: ITPS and EPIA - MII 10000...please help!
    Low Bitrate CherokeeChief's Avatar
    Nov 2004
    Italy
    Hi to all! I have recently received my ITPS. I would like to use it with my Carputer that has a TRAVLA Case C137-120 (www.travla.com) and a MB EPIA Mini-ITX MII 10000. As on intallation intruction of ITPS, there is a little connector (J2) that could send the ON/OFF signal to MB. It colud be connected to the PS_ON on the MB. I don't found a PS_ON connector on the MB, the only one is on the ATX PS connector and is connectected to the Power Supply. I tried to connect that J2 in the same connector of Front power switch, but it doesn't work... I tried to connect in "parallel" to the PS_ON wire on the Power Supply (PS_ON and GND) but doesn't work. The ITPS seems to work well, I have the 12V after 5 seconds from "Ignition" and it goes off after 45 seconds when the key is OFF. The question is: Which kind of signal is on J2 ITPS ? (GND, Contact closure, etc...) Where I have to connect it to my Motherboard? Please help me, this will be the last thing I have to fix before to install my carputer to my car!
    Nov 2003
    Marietta, GA
    Chief,
    I'm afraid your C137 needs +19V input, not +12V....or are you just using the ITPS as a startup/shutdown controller....?
    MikeH
    Constant Bitrate ApoloV's Avatar
    May 2003
    Virginia
    the ITPS just closes the circuit of the motherboard Power_On pins... The Power_On pins are located to the left of the IDE ports (assuming the CPU is on the right looking at it) Its actually the F-panels Via has teh manual online to find the two pins but if i remember correctly its pins 6 & 8 of the F-panel that ITPS J2 connects to..
    2002 DSM RSX-S
    Custom Car PC Re-design Pending Completion of fiberglassing dash and trunk
    Pics
    Nov 2004
    Italy
    Thanks MikeH & ApoloV... I understand what happens now! I need a 12V power supply... confirmed by the tests I done!
    Nov 2003
    Marietta, GA
    ??? +19V ??
    MikeH
    Nov 2004
    Italy
    Quote Originally Posted by MikeH
    ??? +19V ??
    Yes... the power supply inside the case wants 19 V Input in order to supply correct power to MB and other components. If you put the ITPS in the middle between AC adapter and case PS, you will have 12 Vcc regulated that aren't enough to trigger the "Good Power" signal to the PS.
  1. epia m10k + lilliput => gps blocker?
    By NaFooEsi in forum GPS
    Last Post: 04-12-2008, 09:53 PM
  2. WTB: EPIA MOBO / PS / ITPS / RAM / ADAPTERs
    By JoyRidun in forum Classified Archive
    Last Post: 11-16-2004, 12:49 PM
  3. Sale: Epia M10000 + Lilliput 7" touch + PS +ITPS
    By ttoth in forum Classified Archive
    Last Post: 06-13-2004, 07:42 PM
  4. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 11:48 PM
  5. Help with Epia 800 / pw60 / ITPS
    By lalo in forum Power Supplies
    Last Post: 01-04-2004, 03:39 PM
