Results 1 to 9 of 9
Thread: Please HELP!! PSU/ Shutdown controller questions
    Oct 2004
    New Jersey
    Question Please HELP!! PSU/ Shutdown controller questions
    I have a Xenarc MP-SC1 PC and a Xenarx 700 TSV screen and am having a tough time finding the appropriate Shutdown controller or Power suppply solution for this setup. Here are my issues:
    1. Xenarc PC has a DC power input (Barrel plug type) and not ATX connector on the board. The solder points are there but no connector.
    2. PC has no ACPI header on the board (already confirmed with Xenarc Engineering)
    First:
    My theory is, I can probably pull the 12V off the OPUS ATX Connector to get the power to the board but Nat from MP3Car store said that "the OPUS is a smart power supply so it likes to “sense” how much power the motherboard is drawing so it can determine it’s state. I’m not sure how it would perform under your conditions."
    Second:
    Being the PC has no ACPI header can I connect the OPUS/Shutdown Controller directly to the switch on the motherboard?
    What is my best solution for my issues? Do I go with an OPUS or just a shutdown controller? If just a shutdown controller is needed what i sthe best for my solution (Carnetix, Micro shutdown controller from MP3car store, other...)
    Apr 2001
    Portland OR
    Does the 12 volts need to be regulated? To the display?
    Can you provide pictures or links?
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Oct 2004
    New Jersey
    All I could find using the is "It probably does need to be regulated."
    Question about the Xenarc MP-SC1
    Here is the link to the PC Specs
    http://www.xenarc.com/product/mp-sc1.html
    Monitor does not need to be regulated as per this thread:
    Xenarc AC/DC cable
    Here is the link to the screen:
    http://www.xenarc.com/product/700ts.html
    Apr 2001
    Portland OR
    Quote Originally Posted by zootjeff
    -Jeff
    If the computer takes in 12 volts right from the battery and the LCD takes in 12 volts right from the battery, the uSDC20D is perfect for you. All you would need is that. From reading their marketing stuff, they are being ambiguous.
    Now I can't find the specs on the PC saying if it takes in 8-15v or 12+- 5% or what the range is on the input of the PC. If you can make sure about that, then all you would have to do is wire the uSDC up to your display and computer.
    -Jeff
    www.mpegbox.com
    Oct 2004
    New Jersey
    Thanks Jeff, I'll check on the specs for the PC when I get home.
    Oct 2004
    New Jersey
    Jeff,
    This is the response I just got from Xenarc engineering.
    The MP-SC1 does require regulated 12V. We do sell a car adaptor for that unit.
    The 700TSV doesn’t need 12V regulated supplies. It takes 10V DC ~ 24V DC
    So I would be able to use the uSDC20D if I purchased the PC car adapter from Xenarc, Correct?
    If not, what else would you recommend? Would Carnetix work?
    Nov 2003
    Marietta, GA
    RJP,
    I believe the Xenarc PCs use a Sumicom motherboard, which has an integrated, on-board DC-DC PSU. It DOES require a REGULATED +12V supply. The CarNetix P1260 would be a perfect fit for this application.
    However, from what I understand, the Sumicom mobo does not have a seperate ACPI header or input. I beleive one of my customers has soldered 2 wires across the "power" switch and attached them to a small relay, which is fed by the ACPI control signal out of the P1260. Check our forum. I think there are some details of the wiring there.
    FYI....the MP3Car.com store will begin carrying the CarNetix P1260 very soon...
    Good luck!
    MikeH
    Oct 2004
    New Jersey
    Mike,
    Thanks, I also saw your response on Carnetix Forum.
    Rob
    Oct 2004
    New Jersey
    Finally got my Xenarc MP-SC1 running using the Canetix P1260. Works great.... Now it's time to start car install.
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. Commercial shutdown controller
    By Steinola in forum Power Supplies
    Last Post: 12-08-2004, 12:30 PM
  3. DSSC startup / shutdown controller available
    By dashpc in forum Power Supplies
    Last Post: 04-18-2004, 10:00 PM
  4. Inverter, shutdown controller, what else??
    By southprk in forum General Hardware Discussion
    Last Post: 01-09-2004, 06:35 PM
  5. why use a shutdown controller???
    By cyjad in forum Newbie
    Last Post: 12-04-2003, 05:49 AM
