Results 1 to 6 of 6
Thread: How to fix an ITPS when reversing plus and minus
    Oct 2004
    Netherlands
    Hi,
    Well, i got my carputer set up, perfect, then i got a new car build everything in then i made a stupid mistake of reversing the plus and minus on the itps, wham itps dead, bought a new one, worked fine until i bought a backup battery (so my carputer would not die on engine starting) and i reversed the wire's again
    i went to the local electronics shop and got the thing checked out they said two of the diodes where fried, and i got 2 standard ones to replace them,
    so i fixed the ITPS for under 2 euro's. i thought this might be some usefull information i included some pics to show which ones should be replaced.
    the diodes where simple ND5408 Diodes they where 50 cents each
    hope this helps somebody, if not well i tried :P
    this is how the diode looks
    white-label------|||diode|||------red-label
    the red label was facing to the 3 pin connector ( i think red = + but not sure because the guy just said put them like this) you can see on the pictures that the new diode has a grey stripe on one side.
    The old one.
    Two pics of the 'fixed' one.
    Variable Bitrate hevnsnt's Avatar
    Mar 2004
    Nice & Thanks for the info!
    www.i-hacked.com Hardware hacking articles
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Might want to trim down those leads a bit...
    Jun 2004
    The North, Manchester
    buy my spare one from me??
    Dec 2004
    Belgium, Herentals
    my itps died yesterday while playing some music... i'm going to give it a try
    Oct 2004
    Netherlands
    Quote Originally Posted by starfox
    It was hard enough holding them like this making them even smaller would be a pain.
    Quote Originally Posted by OriginalNick2
    how do you mean ?
    Btw, it says in the manual that it has reverse polarity protection with a fuse, (the yellow thing) but that failed twice with me, so much for the protection :P
