swap out the sproggy from the matrix and put it into the supra and see what happens. if it survives that crank, then you know its the battery. if it doesnt it could be the psu.. and then take the sproggy from the supra and put it in the matrix. if that survives, its the psu, if it doesnt, its the battery.
LinkBack URL
About LinkBacks
regarding to SLA battery and heat in engine compartment. If SLA is fine in engine compartment then space is not an issue. If I have to put inside the carbine then that is a BIG issue (fume/space/.... ). SLA setup is my last option before I try other options available.
