Results 1 to 7 of 7
Thread: How to change 12V DC to 6?
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    Here's what I want to do....
    I want to put a PC speaker in my center console where the ashtray used to be. It's a great place for it cause i'll be able to hear it easily and the speaker I have in mind really fits in well without hardly any modification at all.
    Better part is that there's a small light that's 12V DC going into that ashtray that I SHOULD (not sure yet, haven't tested it) be able to use to power the speaker. Only thing is that the speaker is 6V DC.
    Is it particularly difficult to design something to cut that votage in half? It would save me alot of grief trying to run a power supply to the speaker from somewhere else.
    Nov 2004
    I'd probably get one of those cheap little things you can buy at radioshack for like 10 bucks and just set it to 6 volts output. Not sure how many amps you're trying to pull though so just make sure it can handle it.
    Dec 2004
    Baltimore, Maryland
    Quote Originally Posted by triwav
    It's a PC speaker so I can't imagine it could be pulling too many amps.
    Low Bitrate Twopoint's Avatar
    Jul 2004
    Kitsap WA USA
    Napa has a part (12v -6v) that is used for the old 6 volt vehicals, that is relatively inexpensive
    '95 2 door Yukon
    in dash Xenarc 700TSV
    /w HP laptop
    into (installed)
    HU Alpine 9827 \ AMPS MRD-F540 + M301
    MB Quart 216\213 + DVC 10 Sub
    CarPC Pics
    Jul 2004
    New Rochelle,NY
    get a voltage regulator for 5 volts part# 7405 that's usually enough. if not get another one for 1 one volt and bring the outputs in series. I assume you can use a soldering iron. Good Luck.
    Actually they sell the 6 volts ones too:
    http://www.partsexpress.com/pe/showd...artnumber=7806
    left pin 12V input
    middle ground
    right 6V output.
    1A is more than enough for a speaker.
    check me out.
    http://www.mp3car.com/vbulletin/showthread.php?
    t=30304
    Dec 2004
    Baltimore, Maryland
    Quote Originally Posted by Twopoint
    Your idea is the winner for me because it sounds like the option with the least effort needed from me. haha
    But if that part doesn't fit where I ened it, the option from critezzz sounds like it will be really small? I'm assuming?
    And not only can I solder, but I actually enjoy it. (Hey everyone needs a hobby)
    Jul 2004
    New Rochelle,NY
    the unit is very small. size of a penny. make sure you isolate the metal top above the chip. It's ground and the heatsink at the same time. Good luck.
    check me out.
    t=30304
  1. For sale 12v DC + & shutdown controler
    By bertybassett in forum Classified Archive
    Last Post: 05-01-2005, 07:47 AM
  2. 12V DC Arise PSU and Slime DVD ROM DRIVE
    By yourbigfun in forum Classified Archive
    Last Post: 06-06-2004, 10:38 PM
  3. What about 12V DC Outlets that are built into the car?
    By mr_anderson in forum Power Supplies
    Last Post: 01-14-2004, 04:22 PM
  4. Replies: 5
    Last Post: 08-20-2002, 09:32 PM
  5. why not to use zener to make 12V DC??
    By embedded in forum Power Supplies
    Last Post: 04-26-2001, 09:54 PM
