Results 1 to 10 of 11
Thread: Metal hydride batteries
    Anyone got experience of using these? I was talking to someone that said there are newer and better than NiCad batteries. Since my PC draws enough current that the voltage from my tank battery drops below 11.4 V too quickly, I'm tempted to try these instead. Apparently they have practically no internal resistance so can source large currents better than lead acid batteries.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    NiCad is old school. NiMH is the newer breed, pretty safe all around. RC has been using them for years. You rlocal hobby store should have all sized, from 1/2 "aaa" to 1/3 "aa" to sub "c"
    Of course, now we are up to LiPolymer, which is even better yet, but if you overcharge them, they go BOOM in a big way. Not fool proof...yet.
    2005 Ford Focus ST
    How do NiMH batteries cope with overcharging?
    I forgot to mention. He specifically said I needed the type used to power model airplane engines.
    Dec 2003
    Portland, OR
    No battery likes to be overcharged. If that is a fear, I would go for a small sealed lead acid battery. Hobby stores have those as well, for the model engine starters. They are usually 7ah @ 12v, and pretty small. Think of it as a mini-Optima battery.
    look here
    2005 Ford Focus ST
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    There's a thread around here that talks about wheel chair batteries. Apparently you can pick up used ones pretty cheap. That might be a good alternative for you. I have no clue what type they are though.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by Arathranar
    You wouldn't want to use NiCAD batteries. If they are not completly drained before recharging they build a memory, so the capacity will be lowered. They are loved by R/C racers for thier amp's, and a good one will give up full power till its drained. It's funny to see them screaming down the straight and come to a stop in twenty feet with a completly drained battery.
    NiMH can be charged without completly discharging them first with no problem. They don't have the burst of power like the NiCAD's, but that's not important for what you are planning.
    Either way i'm not sure how you plan to charge them. I dought you want to remove them everyday for recharging, and i'm also not sure how well either would react to being charged while in use.
    It's the cake having/eating thing.
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    NiMHs don't like high current drains!!!
    Quote Originally Posted by DjBac
    That's not what I was told.
    I already have a 7Ah SLA battery but the voltage plummets when I try and drive my AMD micro ATX system since it needs so many amps.
    Constant Bitrate NOS TANG's Avatar
    Mar 2004
    OH USA
    Quote Originally Posted by gospeed.racer
    look here
    Found that battery for $17.99 here
    That's about the cheapest tank system you could build in my book.
  1. Two batteries in my ride
    By SAScooby in forum Power Supplies
    Last Post: 10-28-2009, 02:23 AM
  2. Can anyone do metal work for me?
    By EBFoxbat in forum Fabrication
    Last Post: 08-30-2004, 01:18 PM
  3. Questions on batteries
    By Sir_Pyro in forum Power Supplies
    Last Post: 03-25-2003, 09:34 AM
  4. No metal Case
    By nolmscheid in forum General Hardware Discussion
    Last Post: 03-12-2002, 12:47 AM
  5. Powering LCD panel with batteries
    By paulw in forum General Hardware Discussion
    Last Post: 11-01-1999, 02:37 PM
