Results 1 to 10 of 11
Thread: Opus + Laptop + accessories? Or better solution?
    Falls Church, VA
    Yup, I 'd but had a tough time sifting through the hundreds of posts. My searc syntax may not be wonderful.. but the point is this:
    I am running a 650 mhz Gateway P3 laptop as the foundation. I have a 12 volt power supply for the unit, but i believe the laptop input voltage is 18v.
    I have the following accessories: SB Extigy NS (The USB Soundcard, sp?), USB slim line cd/dvd drive, USB keyboard, USB pointing device, USB 802.11b and a USB hub
    I plan on running a Xenarc screen, possibility of a couple gaming remotes and/or an external hard drive... possibly a GPS. Heck, I want the ability to plug and play lots of toys as needed.
    I thought of using the opus 90w device to power the laptop (12v) using the 5v line to power the USB devices... but it seems that I may need more amperage for the 5v line...
    Any ideas? Is there a better way?
    Elsewhere
    Quote Originally Posted by Will Albers
    *SIGH*
    Let's think this through, n00b.
    The Opus is an ATX power supply. Laptops aren't ATX. So using the opus to power your laptop probably ain't gonna happen.
    Your best bet is to get an auto adapter for your particular laptop and wire that to the battery. Don't forget to fuse that line.
    How about the Wiki?
    Falls Church, VA
    Sigh yourself there perv...
    This noob crap is insulting and inappropriate.
    The point of using the opus to power the laptop was that i could connect the 12v adapter power to the 12v line of the power supply creating a clean input regardless of voltage... Would allow the laptop to survive cranking as well as provide a nice clean regulated 12 v. I realize the 12 v adapter for the laptop is *supposed* to provide a clean signal, but i have been sorely disappointed. It does not handle fluctuation in voltage very well at all.
    As an added bonus, i could use the 5v rail to power my USB items.
    So perv, how about a little creative thinking instead of egotistical arrogance? If you have a better set up idea to supply power, please let me know.
    Jan 2005
    Dallas, Tx
    *Stands and starts a slow clap for Will*
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    how many watts is your 18v laptop adapter?
    http://www.mp3car.com/store/product_...products_id=68
    that carnetix psu sounds like what yer lookin for, if your laptop only needs 60 watts @ 12v... otherwise the description sounds like it fulfills the needs you describe, and its a hair cheaper than the 90w opus
    hope this helps!
    (though i could have just put up the "search" emoticon, followed by the "middle finger" emoticon, as well as a "n00b" one... but that would negate the purpose of the forum... AHEM perv)
    Nov 2004
    Cali
    Dude, noob insults aside, what the hell kind of laptop do you have that takes in 12V? most laptops take 14.2V and higher, so the "clean" 12V signal will do nothing for them. Well, may be warm up the battery a little.
    Mar 2004
    Milwaukee, WI
    ? he said it takes in 18v... he has a 12v car adapter
    Nov 2004
    Cali
    Quote Originally Posted by therussman2002
    I don't understand it, if you take a car adapter for a laptop, it will already regulate the voltage as necessary. If he needs 5V line in addition to powering laptop, I am pretty sure it will be cheaper to get a car adpater for a laptop and a separate 5V power supply or step down converter.
    Mar 2004
    Milwaukee, WI
    Oct 2004
    NY
    I see where he's going with this, he wants to use the atx power supply as basically just a power supply for both 12v & 5 v, I guess the 3.3v rail wouldn't be useful much. he can short the p-on leads & the power supply will...well.....supply power.
    I see why he is concerned about running his 18v off of the regulated 12v rather than just ign, because during crank when the battery voltage drops down towards the 10v range, he won't have to worry because his 18v adaptor will still see a good 12v.
    what he is not realizing though, is that by using a laptop he doesn't have to worry about that, because one of the biggest benifits of using a laptop in a car install is that the laptop itself has a BUILT IN TANK CIRCUIT, called a battery, & even if the voltage dipped while cranking it wouldn't matter at all......unless you ripped the battery out of the laptop, which defeats this benifit entirely.
    If the laptop battery is still intact I wouldn't waste all of that clean regulated 12v on running the laptop, & with that in mind, he may want to reconsider using that atx power supply in the first place, BUT i do agree that an atx power supply is still a great supliment to a laptop install, & while some may see it as wasteful because it could be done cheaper, you can also look at it as a great all in one suplimental power supply for the lcd, usb hubs, & any other add on periferals, if he doesn't have to use the power supply to run the 18v adaptor this will leave him plenty of power for everything else, not so bad I think & I am planning another install that will use an opus 150 to supliment a centrino laptop install, the opus start up / shutdown control can be used to actually control the laptop if desired, & there will be plenty of power for any & all periferals that I can connect to this, but I already have the opus, I don't know if I had to go out & spend the $200 for it if I would look for another solution that would cost half that...........
  1. Opus and BMW (e46)
    By captain_jim1 in forum Power Supplies
    Last Post: 01-21-2005, 12:46 AM
  2. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 11:52 PM
  3. Solution for Power for Car PCs
    By riuster in forum Power Supplies
    Last Post: 08-02-2004, 08:37 PM
  4. Hot Hot OPUS!!
    By god_of_cpu in forum Power Supplies
    Last Post: 06-22-2004, 06:02 PM
  5. Replies: 8
    Last Post: 06-05-2004, 11:13 AM
