Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Anybody with an Extra Battery in their car?
    Oct 2004
    Hey guys, this is what I am running in my car and am considering putting an extra deep cycle battery in the trunk because I don't want my lights dimming:
    Biostar M7NCG 400 mobo
    AMD Mobile Athlon XP 2400+ cpu
    Dynatron Copper Cooler Heatsink
    Lite-On DVD/CD-RW Drive
    Soundblaster Audigy 2 PCI Card
    An extra blower
    Rikaline 6010 GPS Receiver
    XM PCR Satellite Receiver
    Xenarc 700TSV Screen
    all off of a Opus 150W Power Supply.
    Also there is going to be this Rockford Fosgate amp:
    Amplifier
    I am planning on running a distribution block that powers the Amp and the Power Supply. What do you guys think? Should I put an extra battery in the trunk? Thanks.
    I did, of course I run almost 2000wRMS of stereo equipment as well. Anyway, I recommend running a 2nd battery any time you are doing a system that will pull as much current as the one you are looking at.
    I have a feeling tho, that the Opus will be forced to continouly output > 150 watts on that setup. It looks like you will likely pull 190 watts, which means a very short opus life. Check it out yourself at http://www.jscustompcs.com/power_supply/
    KyferEz
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    I dont think you'll have to worry about the lights dimming. Most newer cars (90 and up)((just a guess)) have decent alternators that will support that. I'm using an aux. deep cycle optima because I leave the computer running all the time. If you need any help with the aux. battery, if you decide to take that route, just ask.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by KyferEz
    KyferEz
    I was under the impression that the opus would not allow more than 150 watts to be drawn and that if your particular setup required more, then it just wouldn't turn on. I have read of many people with p4 processors running on the opus 150, myself included. now i'm worried that i'll blow up my opus. anyone have any input on this matter?
    _
    Mar 2004
    Little Elm, Texas
    with that set-up, you shouldn't need a second battery to keep your lights from dimming. That's a small amplifier and most stock alternators/batteris should be able to keep up with it just fine. That is of course, as long as you have a car that is up to par. Meaning: as long as you don't drive something that's 25 years old and is on its last leg. If your car is fairly new and maintained you shouldn't have a problem.
    What is your current battery? If it's a deep cycle then you deffinately shouldn't have a problem. All total you are looking at: say 200 for the computer (being generous here) and 400 for that amp (being generous here as well - especially since it's just a punch series and not the power series) - that's 600 watts at most....NOTHING to worry about.
    My suggestion: if you haven't already replaced your current battery with a yellow top or a red top Optima, do it and be done. (we have a red top running in our Supercharged (12psi) dakota RT with a full stereo system that's been in there for 5 years and it's still cranking - show me another battery that's able to take that kind of abuse and keep on going =] )
    EDIT: you might also consider upgrading your wires from your battery over to your alternator if you are able to. Go 1/0 power and ground for that. As for the amp, 4 gauge should be plenty, 2 if you ever plan on adding another amp, and 1/0 if you ever expect to go crazy.
    Also, how are you going to be running that amp? As a 4 channel amp? if so then change that 600watts total to 400 AT MOST.
    Jan Bennett
    Oct 2004
    Hey what kind of supercharger are you running on your Dak? I have a Durango R/T and am thinking of adding a Kenne Bell...
    Also I didn't understand one part of your post...are you saying the Opus 150W won't be enough? Thanks.
    _
    Mar 2004
    Little Elm, Texas
    we are running a Paxton (Novi2000)- DEFFINATELY the way to go if you want some serious power - 345 rwhp (that's something like 415 at the crank)- still on the stock head gaskets - haven't even opened the motor up AT ALL....all stock internals and 85k miles =] The KB is good and all I just haven't been impressed with the times out of them, and they are ugly as hell IMO....lol
    As for the Opus.....I have no idea, I was mostly talking about the second battery for the car - giving you 200watts incase you go with a bigger power supply for the computer.
    Jan Bennett
    Oct 2004
    Quote Originally Posted by legend5761
    Cosco Inverter. They have a 400 watt for $35 and a 1500 watt for $80. I went with the 1500 watt inverter. Now I can do a custom microwave install, to go next to my 80 inch plasma and fridge. LOL
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Aug 2004
    Hudsonville, Michigan
    Quote Originally Posted by n8scstm
    How long does that deep cycle last on the computer will it last all night? I am intersted in seeing pictures/diagrams of you set up
    Nate
    I know what yer thinkin...did he fire six shots or only five...
    _
    Mar 2004
    Little Elm, Texas
    if it does last all night, it won't do it very many times...
    a battery can only be completely drained so many times before it's shot.
    Jan Bennett
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 12:45 PM
  2. Replies: 4
    Last Post: 10-29-2004, 09:10 AM
  3. car battery experiment A SUCCESS!!!
    By chuckctv in forum Power Supplies
    Last Post: 08-29-2004, 11:18 PM
  4. Problem with tank battery - any good Plan B?
    Last Post: 06-14-2004, 10:10 PM
  5. System Restarts whenever I start my car
    By Blue Falcon in forum Power Supplies
    Last Post: 06-25-2001, 06:15 PM
