Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Opus kill switch
  1. #11
    Constant Bitrate naveedh's Avatar
    Oct 2004
    ok, what switch would i need, a push to make switch? maybe. So how would i wire the switch using 2 pins they have?
  2. #12
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by naveedh
    Put a switch (NOT a momentary one) on one wire of the two pins (cut the wire in 1/2 and connect both points to the switch). If the switch is in the ON position then the computer will receive all of the startup/shutdown commands. If its off, it won't receive any
  3. #13
    Oct 2004
    ok what you mean by a non momentary switch. e.g. i have a oem switch in my car which has 4 pins underneath it and you push the switch down it moves down from one side and raises from the other. So is this switch alright?
    Its a bit like this
    http://www.chu.cam.ac.uk/~JRS47/switch.jpg
  4. #14
    Jul 2004
    Berkeley, CA
    Its a bit like this
    Exactly
  5. #15
    Oct 2004
    How do i make use of all four pins? Jsut draw lines like that and label and i should be all set.
    I I
    I I
    Also isnt that going to confuse the opus when it tries to turn the pc on and what will the opus do when i switch the ignition on?
  1. HOLY CRAP.....this is insane
    By cadence117 in forum Off Topic
    Last Post: 06-17-2008, 07:37 PM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  3. Installing On/Off Switch with Opus 90W
    By Judgement in forum Power Supplies
    Last Post: 07-02-2004, 02:43 AM
  4. Switch w/ opus question
    By Mears in forum Power Supplies
    Last Post: 06-26-2004, 12:10 AM
  5. Power switch to the opus
    By XMen in forum Power Supplies
    Last Post: 02-04-2004, 03:22 PM
