Results 1 to 10 of 15
Thread: Opus kill switch
    Constant Bitrate naveedh's Avatar
    Oct 2004
    Opus kill switch
    If i install a kill switch between opus and battery, between +12v and between switched 12v , and use it, is that going to cause my opus any problem at all?
    Jul 2004
    Atlanta, GA
    Won't cause any problem at all. I installed a switch with the center off--that way I can position the switch to the left and use an auxiliary input like a jump start battery unit, center off for valet parking, and to the right for running off of the vehicle battery.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by doctorr
    Neet idea.
    TruckinMP3
    Read the FAQ!
    Dec 2004
    lemme plop what im doin in here since its pretty applicable. allow me to explain the diagram. first off the PAC TR7 does the following: when voltage is applied to it (ignition voltage) it activates something. that something being the relay, which in turn sends power to the OPUS. the switch is there so you can control the ON/OFF of the computer at leisure. Now, when you turn the car off, the PAC TR7 has a timer (you set it), so that at x seconds after ignition voltage is no longer detected, it deactiveates something (again the relay). so you could set it to cut 12V power to the OPUS 2 minutes after you leave the car, leaving time for a proper shutdown and whatever. and voila no battery drain!
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Opus kill switch? use a big hammer!
    on a more serious note, I am not sure what you want the switch to do - eg valet mode, let you turn it on when you want etc etc but what about this:
    power a relay off the Opus standby 12V line which switches the main power to the Opus so when it turns off it kills its own power. Then use some kind of relay/delay setup also wired to activate this relay for a few soconds which is activated by a momentary switch on your dash. Also connect this to the motherboard switch line (using a different pair of contacts) to turn the PC on or use a pulse relay setup on the line into the Opus (you have jsut turned on) to send a pulse to the motherboard (assuming the Opus will be in standby and can be turned on by a motherboard swtch as it is ATX standard). Also have a switch to bypass this whole setup so it acts normally. This way you should have option for completely off until button pressed or normal mode. But it is a bit complicated.
    Oct 2004
    I want it so that when i come to my car and i dont want to use the carputer i can just leave it off using a switch from the from the front. What is the point of a relay? i dont get it..
    Mar 2004
    Bristol
    iIf you want a big switch on your dash (needs to handle over 15amp) then don't use a relay but all car circuits use relays which handle the power. That way you only swithc the low power demand of the relay. Its safe that way and you mount the relay down near your fuse as you don't really want to route all your powr up to the dash were the swtich is.
    Oct 2004
    Thats a bit too complicated for me scouse monkey , simplify it, draw me a diagram
    Jun 2004
    AZ
    ya i am interested in this thread, keep going
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    If you want the computer not to turn on, then just put a small switch on the wire going from the opus to the motherboard to the ON place.
  1. HOLY CRAP.....this is insane
    By cadence117 in forum Off Topic
    Last Post: 06-17-2008, 07:37 PM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  3. Installing On/Off Switch with Opus 90W
    By Judgement in forum Power Supplies
    Last Post: 07-02-2004, 02:43 AM
  4. Switch w/ opus question
    By Mears in forum Power Supplies
    Last Post: 06-26-2004, 12:10 AM
  5. Power switch to the opus
    By XMen in forum Power Supplies
    Last Post: 02-04-2004, 03:22 PM
