Results 1 to 5 of 5
Thread: 120V-AC and 12V-DC together
    May 2004
    South Florida
    Hi,
    I have my carPC working fine with a Opus 90w. I would however like to be able to use the carPC in the house or hotel as a HTPC platform as well.
    What I would like to confirm is can I use both a Morex 60w PSU (w/ standard AC-DC converter attached) and the Opus 90w 12v DC power supply together?
    My plan is to:
    1. Add both PSU's to my custom enclosure
    2. Take the output going to the mobo from each PSU and combine them
    3. Send the combined line to the mobo
    The system would never have input from both the Opus and the Morex at the same time. It will always be 1 or the other. Opus power in car, morex power in house.
    Do you think the above will work or will I have a fried via epia
    Constant Bitrate HoSS's Avatar
    Dec 2004
    I'm not sure thats a good idea.
    It really depends on what the output circuit of each PSU looks like.
    At the very least I would say fit series diodes, but i would be very careful if you try this. Use a dummy load first, instead of your mobo.
    HoSS
    May 2004
    South Florida
    Since I am taking the final output (right before it connects to the mobo) wouldn't they outputs be = (same as standard ATX input to the mobo)?
    I would love to simply get 2 atx extensions (1per PSU)
    Remove the ends that connect to the mobo
    Match all wires from both cut atx extensions and connect them 1 end that will be plugged into the mobo.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by BasicEvil
    Why not just use an AC/DC converter to power the Opus?
    May 2004
    South Florida
    Quote Originally Posted by Laidback
    As simple an solution that is, it never even crossed my mind. Completed it last night working well.
    Upgrading HDD tonight.
  1. Fixed My Buzzing with AC Inverter
    By jjcuff1 in forum General Hardware Discussion
    Last Post: 02-02-2005, 09:15 PM
  2. WTB: Morex 12V AC Adapter
    By Dominik in forum Classified Archive
    Last Post: 10-05-2004, 09:20 PM
  3. What Gauge wires do I use?
    By Showmehow in forum Newbie
    Last Post: 07-25-2004, 10:41 AM
  4. riddle me this - 5V or 12V DC to 100V AC inverter
    By 666 in forum Power Supplies
    Last Post: 07-01-2004, 10:26 PM
  5. DC power supply...HELPPPPPP
    By walid_bmw in forum Power Supplies
    Last Post: 10-02-2003, 01:26 PM
