Results 1 to 8 of 8
Thread: How many wires go to the shutdown controller?
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    I'm going to put in a shutdown controller that will power down my computer and my inverter.
    The shutdown controller obviously needs to be hooked up to a switched power source so it knows when the car is on and off.
    How many wires go to the shutdown controller from the switched power? Is it just one wire from say the head unit that tells the shutdown controller to start up? Or do there need to be two wires?
    Variable Bitrate vcbb5's Avatar
    Aug 2002
    Kansas
    this is what i did:
    http://www.vcbb10.info/ShutdownController
    that's the most recent with pics of my shuttle wired up. I didn't use a cap, so no delay, but it shuts the inverter off after the computer shuts down (leaves on if computer hangs, but that shouldn't happen...much )
    Also uses this for com port trigger: New shutdown controller - software
    more in-depth info: I've soldered in my relay 4 different ways and it still won't work. Help please.
    My Mazda 3s
    My Mazda 3s on Car Domain
    [||||||||||||||||||--] (90%)
    Dec 2004
    Baltimore, Maryland
    Thanks for answering, but can you translate all those colored lines into english? haha It's 1:30 am and I've been at this for hours. I no longer have the ability to read wiring diagrams. Is there one wire running to the shutdown controller or two?
    Apr 2001
    Portland OR
    Which Shutdown Controller are you using?
    Here is some info for the Mpegbox one:
    http://www.mpegbox.com/microsdc/Inpu...ionSchemes.pdf
    Also:
    www.mpegbox.com/microsdc/Quick User Guide 1.pdf
    www.mpegbox.com/microsdc/usdc20d.pdf
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Simple answer:
    Three. One constant on +12volts. One ground. One switched (like the accessory line).
    KyferEz
    www.thecarpcstore.com
    Constant Bitrate cbergeron's Avatar
    The DSSC only requires 3 wires: Constant 12v, GND, and ACCessory.
    To turn on additional devices, such as Amplifiers, USB hubs, etc. You'll require one connection between the DSSC and each respective device. These connections are optional, however.
    Kind regards,
    Chris Bergeron
    DashPC - The Linux Car (since 1999).
    Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
    As seen in the book Geek My Ride
    Thumbs up Typical application with Inverter
    Here is a connection diagram for the DSSC. This image is of an installation using an inverter and the PC's power button (ACPI). DC-DC power supplies would be connected similarly by substituting the Inverter with the DC-DC power supply (ie, Opus, etc).
    Hope this helps!
    Apr 2001
    Portland OR
    Well, since we're all in this fourm, the Mpegbox one only requires 2 wires per a few of the diagrams I posted. Ha!
    +12 and Ground.
    You can add a switch to Accessory or just tie them together.
    -Jeff
    www.mpegbox.com
  1. Please HELP!! PSU/ Shutdown controller questions
    By RJP350Z in forum Power Supplies
    Last Post: 12-23-2004, 03:37 PM
  2. prob with mucha shutdown controller
    By geebee in forum Power Supplies
    Last Post: 12-08-2004, 10:30 AM
  3. Keyless Entry Shutdown Controller
    By Sinorm in forum Power Supplies
    Last Post: 04-07-2004, 09:30 PM
  4. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
  5. Need help hooking up shutdown controller
    By MAJALO1 in forum Power Supplies
    Last Post: 10-08-2002, 02:27 AM
