I helped design it last year. It's basically a cheaper OPUS 90 watt clone. About $85 less.
wow - that was quick...just posted over on that thread of yours....
Ima be irritated if it's cheaper here than I ended up buying it for...lol
EDIT: eh.....cheaper by $5....oh well.....will be posting a review on it when I get it in!
Jan Bennett
ok - well if you helped design it then can you answer my question in the first post of this thread?
please!!!! pretty please!!!
hehehe
Jan Bennett
Should work.Originally Posted by Red GTi VR6
goodie...
thanks for the input!
Jan Bennett
Are you basing 35watt's on the ~1.5v cpu or what it draws in power from the 5 volt line?Originally Posted by arise360
-Mario
Is the voltage regulated as well, it seems like it is by the description but I'd love confirmation of that. Thnks !
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
Have you tried using this psu w/ a reg hard drive. I'll have similar set up but i have a 3.5 inch 120 Gig desktop drive in my machine. Currently I have a 1700+ in it and it pulls about 100-103 watts playing mp3's, peaks about 110-111 during boot, Just havent had time to put the new chip in.
I know my setup would be at the max of this psu, Has anywone pushed the psu to the max to see what it is capable of?
Currently my setup is as follows:
biostar m7nc400
512 ram
1700 xp
120 gig Hitachi HD
gps mouse
USB hub
2x20 LCD
I figure with the new Chip Ill be able to get it down to the 90 watt mark. Any insight as to how this psu may handle under this load?
amd 1700, biostar m7ncg 400, hitachi deskstar 120 8mb , 512 pc2700, liliput 7"
now to put it all together
Yep. Regulated 12V and integrated shutdown controller/timer. Works great on my M10000 system w/ 40GB 2.5" HD. Probably not even drawing near the 90w it supposedly puts out.Originally Posted by IntellaWorks
i'm interested in this product... seems to be what i need!
so from what i understand, i do not have to be concerned w/the power drain of a usb device that is plugged in because the 5svb will shut down after a certain amount of time, and even if it doesnt, the power will completely get cut if the battery drains?
