Let us know!Originally Posted by Red GTi VR6
Also, mention what you use now as I didn't see it on your page...
-Mario
if the unit senses less than 11 volts for more than a minute it will shut everything down, including the 5vrail.....when it senses more than 11v for more than a minute it will start it back up again....
got mine in teh mail yesterday, will hopefully have it ready to install and test out this weekend
Jan Bennett
-Mario
and the opus waits till 10v, which is a dead battery right?
http://www.newegg.com/app/ViewProduc...103-439&depa=1Originally Posted by m3rdpwr
I'm basing this off newegg.com
I have not used this with a 3.5in drive. I am not ruuning my xenarc off it.Originally Posted by blackpacu
Thanks.Originally Posted by arise360
I'll have to check if my 2100+ and 1600+ are .18 or .13 cause I can't remember for the life of me...
-Mario
in my experiences, this is not enough to start a car. And consistently drainin to this point (unless you have a deep cycle battery) will lead to a permanently dead battery.Originally Posted by nsmoller
As far as I know, the Opus 150W NEVER shuts down the +5VSB rail, even if the low voltage (10V) threshold has been reached. The threshold only applies to the other power rails. Thus if given a chance, it will continue to drain your battery until it drops below the minimum required for the Opus to function (I'm guessing ~7-8V).
In any case, if you don't want this behavior there is a thread in the forums with a work around. It involves only a standard automotive relay and a few diodes. Ultimately it doesn't add much to the complexity of wiring it up.
That's my understanding as well.Originally Posted by rando
Only the 90watt opus and the soon to be 220watt opus will do this...
-Mario
There's different settings for the shutdown timing and power off situations. Default is 2 hours after key-off and it'll shut down the 5Vsb, but this can be changed to 'Never', in which case it'll keep the memory 'warm' (for resume from standby) until it detects 11V or less, at which point it'll kill the 5Vsb to save the battery.Originally Posted by nsmoller
