Results 1 to 10 of 10
Thread: Why shutdown controler?
    Mar 2004
    I want use carputer while is engine off.. And I dont need automatical shutdown after stoping engline..
    Whitch powersuply should I buy?
    _
    Mar 2004
    Little Elm, Texas
    what components are you using?
    we need to know how much power you will need before we can recomend a PSU....
    Jan Bennett
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    yeah but you'll be wanting the pc to turn ON with your ignition won't you?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Mar 2004
    Quote Originally Posted by Red GTi VR6
    Via M10000 and 3.5" 120GB HDD
    Oct 2004
    mashina, you should have done a little browsing or searching. The answer was in one of the top 3 threads in this forum:
    use the online power calculator at http://www.thecarpcstore.com/link.ht...alculator.html to figure out your wattage requirements.
    Then browse some of the power supplies mentioned and in the store. If you still have questions, search for a bit, then ask if you still haven't found the answer you are looking for.
    Don't get me wrong, I'm not flaming you or anything, just asking you to do a decent amount of searching first
    ColdPhreze
    14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
    200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
    2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
    Mar 2004
    Quote Originally Posted by Ninja Monkey
    yes it would be fain, but really I dont need this.. i need survive engine 'function' and good cost
    Oct 2004
    See this thread on surviving crank:
    pc corruption
    And as for why a shutdown controller?
    1) life is easier when you don't have to wait for the pc to shutdown everytime you go to get out of the car at the store/movies/etc.
    2) To make sure your battery isn't dead because you forgot to shut off something.
    3) To help prevent the thump that occurs in the amps from turning on the pc.
    4) To help prevent hard drive data corruption by preventing the pc from running in extreme temperatures (high or low).
    ColdPhreze
    Jun 2003
    Chicago
    mashina,
    you need to describe your system in order for us to help advise you better. How much power do you need? What mobo/processor/accessories are you using?
    Mar 2004
    Hi
    I have bought M1-ATX. i payed it at 1.1.2005 and today the PS come. I connected it to mobo and +- .. and .. i dont know whitch word i should to use my english is too bad.. so the ps didnt work.. one of the condenser started to fry and somethink yellow was 'splashing' from it. because I frpom czech republic and I know only one carputer shop (cartft.com in germany) and the express servivce cost 20.. i have repaired it myself.. I bougt new condenser 35v, 470uF . i cant belive it, but now the ps is ok!
    really oskar story or not?
    Oct 2004
    good job mashina.
    ColdPhreze
  1. For sale 12v DC + & shutdown controler
    By bertybassett in forum Classified Archive
    Last Post: 05-01-2005, 07:47 AM
  2. How many wires go to the shutdown controller?
    By Skipjacks in forum Power Supplies
    Last Post: 12-23-2004, 09:51 PM
  3. Please HELP!! PSU/ Shutdown controller questions
    By RJP350Z in forum Power Supplies
    Last Post: 12-23-2004, 03:37 PM
  4. New Improved ATX Shutdown Unit!
    By Danceheaven in forum General Hardware Discussion
    Last Post: 04-15-2004, 10:52 PM
  5. Idea for a shutdown controler
    By owenjh in forum Power Supplies
    Last Post: 12-14-2003, 11:45 PM
