Results 1 to 10 of 18
Thread: Opus Randomnly Restarts or Shuts down?
    Constant Bitrate naveedh's Avatar
    Oct 2004
    My opus was running fine, but now it has been randomly restarting and it is realy ****ing me off. It restarts randomnly e.g whilst watching a film etc.
    Btw its a 150w
    What is the data on your setup, like cpu, ram, power wire size (to opus), is the car running, any other stuff you can think of?
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Maybe the computer is bad? There is this one computer at work that restarts randomly. Can't figure anything out. Dont' even know were to start
    That is a good idea. Test it by taking the PC inside and running it off standard ATX supply for a bit.
    As to where to start troubleshooting a pc that randomly reboots (note that you must run the pc for several days or until you notice it randomly rebooting again after each step):
    1) replace (or swap w/ another pc) the ram. If that doesn't work, goto 2.
    2) format and reinstall. If not fix, goto 3.
    3) Power supply replace/swap. In not fix, goto 4.
    4) disconnect everything from motherboard except hard drive and video (also remove all pci/isa/other cards. If not fixed, goto 5. Otherwise, one of those components is the problem.
    5) cpu swap/replace. If not fixed, goto 6.
    6) Motherboard may be bad.
    KyferEz
    Copper Wire Data
    Oct 2004
    NY
    this is the first signs of overdraw on your opus, try eliminating some of the load, suplimenting with a seperate power supply for a few accessories, or underclocking...
    Oct 2004
    Yeah i think its overdraw, how do i underclock a p4 2.4, i mean what setting sould i set it at. E.g. ??Fsb and what multiplier?, also can there be any sort of damage of underclocking.
    Its a :
    Mini atx mobo
    P4 2.4Ghz
    1x stick 256Mb DDR ram
    Full 3.5inch hd 40gb
    USB Gps Rikaline 6010
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by naveedh
    Its a :
    Mini atx mobo
    P4 2.4Ghz
    You aren't gonna unlock a P4.
    Oct 2004
    y is that?
    Oct 2004
    NY
    If you can't underclock, you can try running drives off of another 12v power supply to relieve the opus a little, just trigger the source from the opus & you'll never know the difference, but I would recommend common grounds. it may just be as simple as powering your dvd drive seperately, or you may need to remove another accessory or two, or just power a usb hub seperate from the opus, depends on how overloaded your opus is...
    Oct 2004
    Iv got a pw-120v so how do i use that in conjuction with opus?
  1. Opus shuts down
    By naveedh in forum Power Supplies
    Last Post: 12-18-2004, 08:53 AM
  2. Wiring two OPUS to one computer system
    By lookinco in forum Power Supplies
    Last Post: 09-07-2004, 11:23 AM
  3. opus 150W shuts off frequently
    By musicthebee in forum Power Supplies
    Last Post: 07-20-2004, 10:48 PM
  4. Replies: 8
    Last Post: 06-05-2004, 10:13 AM
  5. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 04:15 AM
