Results 1 to 10 of 13
Thread: Pulling 2.5 A with everything off??
    Apr 2002
    Houston, TX
    Okay, maybe I am just missing something here, but finally got all the hardware and software setup and am ready to re-install computer and all back into the car.
    For one final check I decided to make sure everything really shuts down when I shut down the system.
    I would explain how all the wiring is done, but I would exceed the post limit to do that.... Anyhow I kept unpulling things to see when the 2.5A draw stop... it never did.
    So I pulled the wires coming directly off the battery and probed them, it was still showing a 2.5A draw... Just wires?????
    Is that normal?
    Any thoughts you have would be most appreciated.
    Jun 2004
    What kiind of car?
    2-2.5A isnt all that uncommon for newer cars when shut off.
    Apr 2002
    Houston, TX
    Quote Originally Posted by Iamthehor
    What kiind of car?
    Well it is a 1984 Corvette, but that is not the issue... not in the car yet. The wire I was probing was a 12" RUN OF 12 gage wires from a test battery to my power header...
    But thanks for the thought....
    I wonder if it is just what the multimeter is pulling, but that wouldn't make sense either....
    Jan 2004
    Jersey/NY
    try unplugging usb devices, if you have any connected.
    and the ammeter shouldn't be pulling anything.. A quick check though, did you switch that terminal when going into ammeter mode? I think a lot of those multimeters require you to do this.. been a long time since I've checked teh amps coming out of something though so I forget.
    And I know you said you can't really discuss your wiring cause it'd take too long, but you think you could give a really short description? It'd help.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    2.5 amps at the battery when everything is off? You've got a problem there for sure! At that rate, your battery will die within a day or two at the most.
    I think you need to give a brief description of your setup (hardware wise) and how it's wired. Also, describe exactly what you did to take your measurement.
    Jun 2004
    Quote Originally Posted by rando
    Note to self - dont try to be intelligent on the morning of jan 1.........
    my multimeter is autoranging - .2 - .25 amps is my normal draw w/o any extras hooked up
    2+ amps is bad in any case
    Mar 2004
    Redondo Beach, CA
    IMHO 250mA is also a bit high to keep your lead acid battery healthy.
    Jan 2004
    How are you testing this? The ammeter has to be in series with the circuit, not parallel. (you can't check amps like you can volts)
    Jun 2004
    when i worked at sears we would sometimes have to check for drains, and that seemed to be about normal for quite a few cars. especially considering that includes the light under the hood. mine gets cut in half with the light unplugged
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Pull out all the fuses until it stops, if you really want to know what it is. That might mess up the radio anti-theft thing though.
  1. Replies: 3
    Last Post: 06-04-2004, 11:43 AM
  2. Replies: 3
    Last Post: 02-01-2004, 02:02 PM
  3. Sproggy 2.5 PSU. Can i run Via epia 5000?
    By tomis_86 in forum Power Supplies
    Last Post: 11-19-2003, 12:18 PM
  4. looking for small 2.5 x 2.5 inch display
    By edie209 in forum LCD/Display
    Last Post: 05-04-2001, 04:29 PM
  5. 2.5" Color LCD with Composite-in and Backlit
    By dos4who? in forum Classified Archive
    Last Post: 08-22-2000, 12:46 PM
