Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: power up opus without car started
  1. #11
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    You need a single poll, double throw switch (SPDT). Mechanically it's like an on-off switch, but it's real use is as an on-on switch. In one possition you provide one path for voltage, and in the other possition you provide another path. You can also call it a changeover switch.
    I used a single poll, double throw switch (SPDT) for my ACC. I attached the ACC-IN wire for the power supply to the "COM" of the switch. Then I connected ignition power/ACC power from the car to the A terminal of the switch, and a live 12 volts to terminal B. When the switch is in the A possition, it closes the connection for ignition power from the car. When the switch is in possition B, it closes the live 12 volts to the ACC-in of the power supply.
    - Connect ACC-IN wire from OPUS to "COM" of switch.
    - Connect ignition power (ACC power) to terminal A on the switch
    - Connect live 12 volts to terminal B on the switch
    Possition|-ACC/Ignition-|-Live 12 volts-|
    ---A----|------ON-----|-----Off------|
    ---B----|------OFF----|-----ON------|
    When you put the switch in possition B you can turn off the car and run into the store for five minutes, and the PC will stay powered on. This is because possition B sends 12 volts to the ACC-In of the power supply and tricks it into thinking the key is in the ON possition. You can also use this trick to turn the PC on as well (be aware of the 4 second power on delay). The trick is to not forget to change the switch back to possition A. If you forget, the PC will stay powered on while you sleep at night and drain your battery.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
  2. #12
    Jun 2004
    Toronto, Canada
    I just found a simple schematic by someone else. It's for the ITPS, but the concept is identical. Schematics/Pin Outs/Diagrams
  1. Will an OPUS power back up once the battery is charged?
    By The Grinch in forum Power Supplies
    Last Post: 10-13-2004, 06:41 PM
  2. 2 OPUS and seperate power source for Video & sound card
    By lookinco in forum Power Supplies
    Last Post: 08-27-2004, 06:44 AM
  3. 2699 case with opus 90w power supply question
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-04-2004, 02:32 PM
  4. Mp3Car.com Store carrying OPUS Power Supplies
    By Zip-Lock in forum Classified Archive
    Last Post: 02-24-2004, 11:39 AM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
