Results 1 to 10 of 12
Thread: power up opus without car started
    Newbie javii's Avatar
    Dec 2004
    Orihuela, Spain
    i'm planning to install my carputer with an opus 150w and get connected/disconnected with the ignition key. But i have question, is it possible to power up the carputer without having the car started?
    regards
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    yes
    Signature: [==||========] 20% complete
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Turn the ignition key to the on position.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    Are you asking if it's possible to start the PC without the engine running, or without the keys in the ignition?
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
    Dec 2004
    Orihuela, Spain
    i was asking if it's possible to start the PC without the keys in the ignition, with a switch or something like that
    thanks for your answer
    Newbie Dirk9N's Avatar
    Jul 2004
    Germany
    sure its possible, simply bypass the ignition by an Switched wire. But the big problem is, you could forget to turn the switch of, so your pc emptys the bat.
    a try to show the wiring plan:
    .../-----perm 12V---------\
    bat -----ignition-----------PSU
    ...\------Switch-------/
    / & ---=Wire
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    the opus will shut down before the battery is drained...
    rebuilding carpc... kinda..
    Dec 2004
    Orihuela, Spain
    mmm thank you for your help, i think i'll keep my keys in the ignition
    Jun 2003
    Atlanta/Augusta, GA
    Quote Originally Posted by fantomas
    It should, however it may not shut down soon enough in some cases. My Opus 150W has drained my battery a few times. It did shut down during low voltage, unfortunately by this time there wasn't enough juice left to crank.
    Plus, the 5VSB rail is always on leeching power. Depending on the power used by your USB devices, you may want to disable the rail when the computer shuts down (see the relay mod post for the 150W or set the jumper on the 90W).
    I killed my first battery because of a combination of the above.
    Nov 2003
    CT
    hmn...you could set a momentary switch that sends a signal to the opus to turn on, and set the jumper on the opus to 30 or 60 minutes so it automatically shuts down after this time unless you hit the button again or actually start the car
  1. Will an OPUS power back up once the battery is charged?
    By The Grinch in forum Power Supplies
    Last Post: 10-13-2004, 05:41 PM
  2. 2 OPUS and seperate power source for Video & sound card
    By lookinco in forum Power Supplies
    Last Post: 08-27-2004, 05:44 AM
  3. 2699 case with opus 90w power supply question
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-04-2004, 01:32 PM
  4. Mp3Car.com Store carrying OPUS Power Supplies
    By Zip-Lock in forum Classified Archive
    Last Post: 02-24-2004, 10:39 AM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
