Results 1 to 10 of 10
Thread: inverter + laptop problem
    Newbie javii's Avatar
    Dec 2004
    Orihuela, Spain
    i'm having problem with a 300w inverter and a laptop, i have connected the inverter directly to my battery, and then connected to my laptop, i can see the laptop lcd charging his battery, but when i push the power on button on the laptop, the inverter does BEEEEEEP!, and the battery led on the inverter change from green to red, and the come back to green, and the laptop seems to be reseted and doesn't boot up.
    But if i disconnect the laptop from the inverter, and then power on directly from his own battery, it starts (of course), and if I then connect it to the inverter, the laptop keeps on and charging his battery without any problem.
    any help would be appreciated
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    is that a 300w surge(max) or 300w continuous? Not that it matters much because either way it should be over the required watts for a laptop. I know that some rechargable devices will not operate correcly(in fact it will kill the batteries) if your using a modified sine wave inverter (like you most likely have) rather than a pure sine wave inverter (which costs a fortune). Anyone know if mod. sine inverters will harm a laptop battery?
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    I have used an el-chepo inverter with a laptop for years, no problem. Most likely there is some other issue. What gauge wire did you use to connect the inverter to the battery, and how long is that wire?
    The red light is most likely occuring because the inverter is sensing a low voltage, which leads me to believe you used too small of wire.
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
    Oct 2004
    Its only a 300 watt inverter so a 10 guage wire at 15 feet would be sufficient. I didnt mention that because I assumed that he at least used 10 gauge wire. But you know what they say when you assume something. "You make an *** out of u and me." Sorry for missing that.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    What's the output on the Laptops transformer brick? If it's 12 you could bypass the inverter infavor of a regulator.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Jan 2004
    maybe the car's battery just didnt have enuff voltage to power the laptop right away (after starting the car)... try it without the car on... or after starting the car give it a minute
    AT mobo
    Intel Pentium MMX 233mhz
    ESS Solo PCI soundcard
    Linksys NIC
    Irman
    Dec 2004
    Orihuela, Spain
    i'm not sure which one it's, i haven't it here (it's in the car), in the box it said 300w inverter
    I'm using the wire which came with the inverter, it's about 1 or 1.5 meters (3 or 5 feet said my nokia phone ), it's a temporary install still.
    18.5v 3.5A
    i have tried it
    thank you for your help!
    Oct 2004
    Does that mean it worked? If so, consider using a capacitor to compensate for those variations. I dont think it would take a very large one for something like that. Maybe a half farad.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Dec 2004
    Orihuela, Spain
    nope, sorry, i tried it but it didn't work
    Dec 2004
    Orihuela, Spain
    Here is a copy of my inverter specifications.
  1. Laptop + Monitors How can they work together?
    By cyrescs in forum LCD/Display
    Last Post: 12-29-2004, 02:39 AM
  2. Replies: 12
    Last Post: 12-08-2004, 10:03 AM
  3. Help with inverter
    By Starkan in forum General Hardware Discussion
    Last Post: 07-10-2004, 07:43 PM
  4. Need help with setup..laptop, hibernate, external hdd
    By Kato in forum General Hardware Discussion
    Last Post: 06-25-2004, 01:43 PM
  5. I have searched. How do I start up this laptop.
    By Audamn in forum Power Supplies
    Last Post: 12-23-2003, 01:04 AM
