Results 1 to 8 of 8
Thread: Rage!!!! Rage!! Rage!!!
    Dec 2004
    Angry Rage!!!! Rage!! Rage!!!
    I am really ****ed,
    My 60W Morex P.S that came with my Morex case does not work after I plugged it in to the Carnetix! I hope its just the P.S and not the MOBO. I tried pluging the computer back into to the Brick P.S and NOT WORKING!! Even though it worked perfect BEFORE I messed with the Carnetix! I don't have anyway of testing the MOBO now because I need to order a NEW MINI ITX P.S!! Anyone ever have a problem like this? That Carnetix was working just as advertised after I hooked it all up correctly..perhaps it shorted the Morex P.S? Whatever happened I am really really really really ****ed off! And may just give this crap up and use my laptop.
    Dec 2004
    I have the VIA M10000.
    Oct 2004
    there is a surface mount fuse on that mini itx psu. it may have blown, it's worth checking. It close to the connector for the input voltage on the psu's pcb board (not the case).
    14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
    200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
    2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
    Dec 2004
    How do I replace this fuse Also I cant find it..
    Nov 2003
    Marietta, GA
    Do you have your motherboard connected to the Morex when it's "not working"? What are the symptoms? When you turn on the P1260 can you measure +12V at its output? Does you mobo/CarPC show any signs of life (ie HDD spinning, fans, LEDs etc)? What else is connected to the Morex?
    Dec 2004
    The P1260 give off a nice 12V DC current, but the MOREX P.S will not pump it back out to anything, (I have tried plugging the MOREX in to the wall and not the P1260 and still the same results, nothing..I even disconnected it from the MOBO and tried it, NOTHING, I tried to plug in only some fans and Hard Drive...NOTHING. I Used the voltmeter to test the current, it goes IN to the MOREX but nothing comes OUT. I have already purchased another MOREX P.S, I have praying that when the first MOREX blew, it did not fry the MOBO. Honest, perhaps I hooked up the CARNETIC wrong and that is why it fried the MOREX, hopefully it will not happen again.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    When you did your testing, did you pull the Morex PSON signal to ground? It's not going to come on otherwise.
    Jan 2004
    Thumbs up
    Rando - Do you know which pin on the Morex is PSON? I've tried to use that same PS to power our Dashpc, but I could never get the PS to turn on.
    I've heard that the Morex PS requires a power draw before it can turn on, but I'm not sure if that is truely the case.
    Our DashPC draws ~2 Watts (at 5v), so the Morex PS can clearly power it. It's definately overkill, but I'd just as soon play it very safe with our precious prototypes.
    Your thoughts?
    Kind regards,
  1. Replies: 5
    Last Post: 04-21-2005, 02:17 PM
  2. Rage against some stupid things
    By kraft in forum Off Topic
    Last Post: 11-07-2004, 05:29 PM
  3. Ati Rage Pci Support C-Sync ( For Psone Lcd Mod )
    By Madboy in forum LCD/Display
    Last Post: 10-31-2004, 04:00 PM
  4. 2002 Nissan Frontier - aka Road RagE
    By PS-RagE in forum Show off your project
    Last Post: 09-22-2003, 10:45 PM
  5. ATI RAGE card for cheap on ebay...
    By flipSyde in forum General Hardware Discussion
    Last Post: 08-23-1999, 02:38 PM
