Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: UPS run from inverter?
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    I have a XS800 by APC running my home computer. I was playing around when I first initially set up my carputer and the (EDIT2:ups NOT inverter) would keep switching from online (ac source) to battery mode, every 5 seconds, even when the car was running. Is that because of the sine wave caused by the inverter? Or SHOULD the battery backup work? I don't see a reason why not if its getting it from an AC source and everything else is running off that AC fine.
    Has anyone hooked up a UPS off an inverter? I dont understand why it wouldnt work, and it would be a HUGE help because this current setup (my athlon) draws alot of power so I cant turn the car off and back on, or have it off for 5mins (while I pump gas or something) because when I crank it restarts. My old setup with an 800mhz duron and 250w psu would be fine after 20mins of having it run off the battery, voltage would go to 11.0V and it would still crank and allow it to run. Now when I turn the car off it goes to 12.2V and if it goes below 12.0V it will restart the computer. I've done it twice to try to find the sweet spot, but it barely exists.
    Stupid power hungry PC
    EDIT: And while I'm here is it true inverters are only 50% efficient? I know its not very efficient, but I wasnt sure if it was as low as 50%. So my 800w inverter on full load would really need 1600w to run, or can the 800w inverter only supply 400W?
    With my system cranked, with 4 speakers at max 90w + computer+monitor +charging my phone + USB Hub I dont go above 180W (according to the inverter).
    EDIT 2: Oops at the top I said the ivnerter kept switching from online to battery, I meant the UPS.
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Its more efficient than that. I think somewhere around 85%. It could be that your using a modified sine wave inverter. Contact the manufacturer of the UPS and see if it requires a pure sine wave. You could buy a capacitor and place it before the inverter. 1/2 farad should work for that. And just forget about the UPS.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Jan 2005
    Saskatoon, SK
    I was considering using a capacitor instead aswell which actually might be even better and cheaper, maybe I should go with a larger cap? 1/2 farad should be good, but I havent really dealt with caps before.
    Inverters are really 85% efficient? Wow, I thought it was lower, then why dont more people use inverters instead of dc-dc psus? I paid 100 bucks for the inverter and 55 for my 420 TT PSU, all tax in. I've seen some 250w dcdc psus for like 200 bucks. Whats the deal?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    I did hear on here that UPs don't like inveters. i am sure someone has done a post about this before.
    Oct 2004
    Well for one thing inverters take alot of room compared to an OPUS. I went with the inverter so I can plug other stuff in. All said and done, I spent way more on the inverter setup than I would have on an OPUS.(aux batt, isolator, cables, inverter, fuses, volt meter, junction block) It all came to about $500.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Jan 2005
    Saskatoon, SK
    My inverter has a digital read out of input voltage, wattage and output voltage on it. Right now (until I mod it) it sits under the dash totally out of the way, the fan is loud in it, so it needs to be modded for setup #4
    Inverters do NOT work off of modified sine wave inverters. They May work with a sine wave inverter, but it depends.
    One possible method to use a UPS is to connect the battery terminals from the UPS to the car battery, don't connect it to AC at all. Some inverters will work this way; they allow you to turn them on without AC power. Some won't. This would be fairly efficient, but not very small.
    And when using an inverter, don't forget to use a startup shutdown power controller. They make life so much easier.
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
    Oct 2004
    What ups has a battery terminals? Ive never seen that before. And then it would only be 12 volts. How would you plug anything into it? You really lost me!
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Jan 2005
    Atlanta, GA
    Open up a UPS. Batteries are inside... How do you think it keeps running after you unplug it?
    Jan 2005
    Saskatoon, SK
    Hmm, is it 12V really? Either way I wont be doing this. I dont have a start up shutdown controller, but the button is right next to my ignition to hibernate (which im having troubles with grr) and sometimes I want to leave it on when the car is off (pumping gas) but Im having problems with cranking with this system, it doesnt like the low voltages like the old psu did.
  1. Found someting interesting on E-Bay!!!
    By outragis in forum Classified Archive
    Last Post: 01-23-2006, 09:38 AM
  2. Help with inverter
    By Starkan in forum General Hardware Discussion
    Last Post: 07-10-2004, 07:43 PM
  3. inverter question
    By johnyeros in forum Power Supplies
    Last Post: 05-21-2004, 03:21 PM
  4. 150watt inverter will be running comp &lcd ?
    By liquid85 in forum LCD/Display
    Last Post: 12-06-2003, 02:39 AM
  5. FS:HYPERION Simplicity Series standalone Controller and inverter
    By kickercivic1 in forum Classified Archive
    Last Post: 06-25-2003, 10:01 AM
