Results 1 to 10 of 13
Thread: limitations of OPUS 150W dc/dc
    Oct 2004
    i need a psu for my P4 2.8, 512 ram computer.
    would an opus 150w be enough?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    "limitations of OPUS 150W dc/dc" i bet it makes **** coffee and won't be much company on a lonely winters night.
    It should run that i think but we need more specs.
    ie what pci cards
    grpahics card
    what hard drives and how many
    same for optical drives
    etc etc
    your question is a bit too vague. Have a look at some other systems on here, a few people with hight power are considering dual opus or you might have to power your drives from another seconday psu e.g. a 90W one. There is a power calc outhere somewhere and there will be a link to it if you search (i aint finding it for you i spend far too long on this forum) but i suspect your cpu will draw somewhere between 60-80watts alone. There is an Opus 200w coming out and that should be fine.
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    probably
    goto http://www.jscustompcs.com/power_supply/ and put your system together with that tool
    it will show you the "max" power of a psu you should have
    on the spec manual of the opus it lists the max current at each of 12v, 5v, 3.3v, etc. I added up the watts of each max value and found 190 something... the above tool told me My p4 2.8 setup would need 175watts max, so i figure that should work
    someone tell me if im wrong
    Mar 2004
    Bristol
    on another note do you need 2.8ghz? you may do and each to their own if you don't then don't use it yo will just be putting uncessarsary load on your PSU and taking power that drives or PCI cards may need.
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    Tinanium : funny man you(personal)
    hmm..says 250 watts...
    http://www.orbitmicro.com/products/p...2/KPDX250H.htm
    9v prob wont survive crank...
    DICE Los Angeles
    May 2004
    Hollywood
    there might be solution...Frys has cheap(45$) motherboards with duron(~45w)...before we order anything...we can go pick up a board there(if they still have it) and order the 90w psu..in turn makign the budget
    DICE Los Angeles
    Oct 2004
    damn, i already ordered everything
    Mar 2004
    Bristol
    Quote Originally Posted by titaniumkingpin
    oh dear, i'll take it off your hands for 20 bucks if you don't want it.
    Oct 2004
    umm. no
    Mar 2004
    Bristol
    Poo
  1. OPUS 150w keeps killing my battery. Need help!
    By EuroFan in forum Power Supplies
    Last Post: 10-20-2004, 07:04 AM
  2. Replies: 8
    Last Post: 06-05-2004, 10:13 AM
  3. Closed - Possible Opus Group Buy
    By BoraXP in forum Classified Archive
    Last Post: 05-18-2004, 10:03 AM
  4. Will a 150W OPUS power this?
    By mbkowns in forum Power Supplies
    Last Post: 04-14-2004, 02:17 PM
  5. Jumpers on the OPUS 150W DC/DC psu
    By t0ffluss in forum Power Supplies
    Last Post: 01-21-2003, 09:14 AM
