I will have it hooked up to a home car battery charger, will it work so I can do testing?
Yes.
Ehh its not working.
Positive to positive.
Negative to negative.
2 pin power wire connected from Opus to MII
I connect the ACC-ON wire to 12v positive, nothing happens. I don't see a green LED either. I can't even find it on the Opus, it's definitely not lit up though. Fuse is not blown.
*edited*
I read that you can make it work. Seems like you connected everything correctly. :confused:
Does the needle go up on the battery charger when you connect it to the battery? If it doesn't your battery might be dead - happens if they are left discharged for a while.
Do you have the ATX connector plugged in too?
Note: You need at least 12 guage wire for the pos and neg connections. Don't use anything less or else it won't power up :)
:tard:Quote:
Originally Posted by Bailey
Take a quick look here for me? Thanks...Quote:
Originally Posted by 0l33l
http://www.mp3car.com/vbulletin/general-mp3car-discussion/40488-can-someone-double-check-my-opus-wiring-please.html
Atleast you got it to boot. My job here is finished :cool:Quote:
