Results 1 to 10 of 10
Thread: Quick question - Can I power the Opus 90w in the house with a spare car batt?
    Variable Bitrate Bailey's Avatar
    Nov 2004
    NYC
    I will have it hooked up to a home car battery charger, will it work so I can do testing?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Yes.
    Nov 2004
    NYC
    Nov 2004
    NYC
    Ehh its not working.
    Positive to positive.
    Negative to negative.
    2 pin power wire connected from Opus to MII
    I connect the ACC-ON wire to 12v positive, nothing happens. I don't see a green LED either. I can't even find it on the Opus, it's definitely not lit up though. Fuse is not blown.
    *edited*
    Jul 2004
    Berkeley, CA
    I read that you can make it work. Seems like you connected everything correctly.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Does the needle go up on the battery charger when you connect it to the battery? If it doesn't your battery might be dead - happens if they are left discharged for a while.
    Do you have the ATX connector plugged in too?
    Nov 2004
    NYC
    Note: You need at least 12 guage wire for the pos and neg connections. Don't use anything less or else it won't power up
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Bailey
    Nov 2004
    NYC
    Quote Originally Posted by 0l33l
    Take a quick look here for me? Thanks...
    Can someone double check my Opus wiring please
    Jul 2004
    Berkeley, CA
    Atleast you got it to boot. My job here is finished
  1. can I power a car stereo with an ATX PSU?
    By Fourgig in forum General Hardware Discussion
    Last Post: 09-08-2009, 07:40 AM
  2. Can Opus 90w power these?
    By harrisonpowers in forum Newbie
    Last Post: 11-25-2004, 10:28 PM
  3. 86% Efficient AC-DC ATX supply
    By auto_robotics in forum Power Supplies
    Last Post: 11-25-2004, 03:16 AM
  4. quick question re: laptop power
    By mkerr in forum Power Supplies
    Last Post: 10-22-2004, 12:37 AM
  5. Opus DC-DC 90W 150W Pricing Dimensions Info
    By Linus in forum Power Supplies
    Last Post: 10-15-2003, 04:29 PM
