Results 1 to 3 of 3
Thread: CarPuter wont hibernate now.
    Low Bitrate djtrickee's Avatar
    Aug 2003
    Denver, CO
    Here's what I am running-
    Epia m10k, Opus 150, Windows XP pro. Lilliput TS
    Everything worked fine for the past few months till I had some problems with my lilliput. Bought a new one, and in the process I had to Reset the BIOS on the mobo. Now, I cant get the damn thing to hibernate or shutoff when the car shuts off. It used to work fine, would go into hibernation 10 seconds after removing the key just like it should.
    I have read and re-read the manuals for the m10000 and the opus and cant figure this bugger out. The opus manual says to setup your BIOS and enable the APM function, but I cant find this anywhere in the BIOS. only apci. when i get into windows I can enable the hibernation function and get it to hibernate either from frodoplayer or holding down the shift key, but when I take away the switched power to the opus (remove key from ignition) the PC stays on forever.
    Anyone think of anything I am missing or what do I need to do to get it to shutdown properly?
    thanks a bunch.
    -chris b.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    2 things. Make sure your power switch lead from the OPUS is for sure hooked to your power switch header on your Mobo. 2, check to make sure XP is set to Hibernate when you press the power button. After that... I dunno man.
    Also, hook up a power switch to your header on your mobo to test and make sure that part is working, maybe the switch in your opus is bad.
    Tidder
    Try RevFE
    Aug 2003
    Denver, CO
    Thanks I didnt want to have to rip the whole thing out of the dash again, but I cant get it to turn on. Its gotta be that power switch wire me thinketh. I see the opus working and all the usb parts come on, but it wont trigger the pc to turn on. and of course I set the BIOS to not resume on ACC Loss.
  1. 99 Acura TL carputer project pics
    By Darkshear in forum Show off your project
    Last Post: 08-23-2007, 01:14 AM
  2. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  3. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  4. My Weekend of carputer hell!
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 01-05-2005, 09:19 AM
  5. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
