25 amp fuse as close to the battery as possible. An inline fuse that's easy to change.
Hey, quick question.
I plan on using 10 guage wire to connect the Carnetix to my battery, and 18 guage for the rest of my wirring, speakers, etc,
Should i put some sort of fuse in line before reaching the carnetix?
If so, what size fuse? (rating)
I plan to power my car pc, lcd monitor, and xm radio adapter(12v also) off of the carnetix.
Thanks,
Sean
The carnetix installation instructions say use a 10Amp fuse.
10A fuse should be OK. You're really just protecting against a short in your supply wire from your battery to the P1260 with this fuse. The P1260 does have a built-in self-resetting fuse to protect its innards.
10GA wiring should be OK so long as your runs aren't outrageously long (<12ft-ish).
MikeH
Mike,
If I get a carnetix and don't feel like installing it myself, what would you expect a random car audio installer to charge to install it?
ran it last night, simple as can be linden. ran a 10 guage wire with a 10 a inline fuse from walmart from the battery thru a grommit in my firewall, and then hooked everything up...no worries.
