Results 1 to 4 of 4
Thread: Splitting ACC line
    Dec 2004
    Wichita Falls, Texas
    Splitting ACC line
    I removed my Headunit from my car and I found the one labeled
    "Ignition-Switched Input"
    This is the correct wire to connect to the yellow wire on my opus correct?
    And is it ok if i run a total of 3 wires from it. 1 to the opus 1 to the Subwoofer amp 1 to the 4channel amp?
    If not how would i go about getting remote wires to the amps so that that they turn on too?
    Or would I need to do something like split one of my molex 12v connectors and run them to the amps?
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by koolaidkitten
    Sounds like it, just use a test light to be sure.
    Should be ok.
    IMO, I like running as much power as possible directly from the car. Sounds to me like you're on the right track.
    This is the way I ran my stuff, however I ran power to my amp through my cruise control relay, this way I can turn on my amp (through the steering wheel cruise button) after the pc has booted up. (To elliminate pop noise)
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Dec 2004
    Thank You.
    Will be putting it in tonight. I hope i don't fry anything important
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Do you have a multimeter? It's always good to test things before you plug them in and a simple multimeter isn't expensive.
  1. Techies - matching line output levels ???
    By slushieken in forum Car Audio
    Last Post: 09-10-2004, 04:57 PM
  2. Question about acc line
    By jermkesler in forum Power Supplies
    Last Post: 08-28-2004, 03:17 AM
  3. How do I get my ACC +12v line to drop to zero
    By SAScooby in forum Power Supplies
    Last Post: 08-22-2004, 02:13 PM
  4. Question on Line Out of M10000 and Audigy NX
    By Mears in forum General Hardware Discussion
    Last Post: 06-10-2004, 05:00 AM
  5. Easy way to mute/unmute line in ?
    By liquid_smoke in forum General Hardware Discussion
    Last Post: 12-31-2003, 02:02 AM
