jameco.com, digikey.com... If you don't want to order it, Radio Shack #274-1565 may work. You could try checking the local electronics repair shops too.
Other than that, the electronics junk pile you may have lying around
KyferEz
KyferEz
TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
PSU Wattage Calculator
Electronics Calculators
Copper Wire Data
I don't have many DC psu's lying around as junk
I should have specified - I was thinking shops rather than Internet as I want to have it tomorrow. I'll give Radio Shack a go - any other suggestions of shops?
274-1565 is the female part. I need the male part but a quick search shows they have many subtly differently sized DC plugs to choose from. But I'm clearly going to have the take the PW200-V with me since I can't measure it accurately enough given the small differences in potential plug sizes.
You want the 2.5mm male plug.
Kind regards,
CB
DashPC - The Linux Car (since 1999).
Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
As seen in the book Geek My Ride
Yep, the 5.5/2.5mm one was the one I needed. It even came in 2-count packs so I may get some of the female sockets and use that to hook in other 12V devices to the output of my regulator.
