With respect to linear voltage regulators (such as a 7812), they have what they call a "dropout". Dropout is the minimum amout of voltage the device will drop. So if you have a 12V reg with 2V of dropout, then you need 14V at the input. Anything less will result in a undervoltage output.Originally Posted by Arathranar
The actual dropout will vary with the amount of current you are pulling thru the regulator, but it is typically 1 - 2V (been a while since I looked at a vreg datasheet) for a standard vreg.
"Low Dropout" regulators tend to have about 300 - 500 mV of dropout.
Typically, the dropout is fairly constant (at a particular current) once you have an undervoltage situation. So if you feed 10V into a 12V regulator with a .5V dropout, your output should be 9.5V.
LinkBack URL
About LinkBacks
