OPUS 150, done.Originally Posted by rainman1
Just curious if a 150-200W M1-atx is in the works...anyone? I am using a microATX motherboard with a mobile athlon (45W) which seems to me needs AT LEAST 4A to be able to run. I am getting such a headache trying to figure out what the best power option is!
thanks!
opus does 5 amps max at 12v... if its at least 4amps, and at most 6, opus MAY worki think "peak" is 6.5amps at 12v on opus
OPUS 150 probably would work, but I don't have $200 for a power supply! If you think about it, that's more than the MB, cpu, HD combined! Looking for a cheaper, 1 piece solution
PW-200V plus 7.2Ah sealed lead acid battery tank circuit. That's the route I'm going. It'll be sub-$100 total when I'm done (of course it'll cost me more since I'm buying spare components in case I blow them up...!).
