Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Opus 90W Problem: No led flash, doesn't power up
  1. #11
    Jan 2005
    I replaced it, but the problem wasnt solved.
  2. #12
    Jan 2005
    Anyone another idea to try?
  3. #13
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    I noticed it locked up sometimes, I would have to disconnect it from the battery for about 1 min. Then it would work.
  4. #14
    Jan 2005
    I've disconnected it from battery for more then one day, doesnt work
  5. #15
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    I don't own one but there seems to be a lot of posts lately related to problems with the 90W Opus. Maybe time to send it in if it's still under warranty.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
  6. #16
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    Did you take the power supply inside the house? If not, bring it inside and warm it up a little with a hair dryer. Then go back to the car and quickly hook it up. If the LED starts to flash, then you have the same defect as the rest of us. OPUS has a fix now, but requires that you send it in for repair. (under warranty)
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
  1. 86% Efficient AC-DC ATX supply
    By auto_robotics in forum Power Supplies
    Last Post: 11-25-2004, 03:16 AM
  2. Will an OPUS power back up once the battery is charged?
    By The Grinch in forum Power Supplies
    Last Post: 10-13-2004, 06:41 PM
  3. blinking power LED
    By tunnel vision in forum General Hardware Discussion
    Last Post: 09-21-2004, 01:45 AM
  4. Opus 90w Shutdown Power off Porblems
    By antimatter in forum Power Supplies
    Last Post: 04-15-2004, 12:24 PM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
