Results 1 to 3 of 3
Thread: shutdown command through parallel port
    Is it possible to tell windows to shut down via the parallel port? How about a USB port? Both serial ports are being used already
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    You could use a USB keyboard with a power button. Or you could get a USB->Serial dongle and use the built-in UPS service to shutdown windows. Alternatively you could write some code to monitor whatever port you want and shutdown windows.
    Constant Bitrate cbergeron's Avatar
    TurboChris, you can shutdown your computer using the parallel port with the DSSC shutdown controller. We can provide you with code and examples of how to do it using our controller.
    It's simply a matter of connecting 2 wires from your parallel port to the DSSC to make it shut down properly.
    Kind regards,
    CB
    DashPC - The Linux Car (since 1999).
    Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
    As seen in the book Geek My Ride
  1. parallel port LCD problem
    By jethari in forum LCD/Display
    Last Post: 09-05-2004, 10:56 PM
  2. Help: Reading from parallel port
    By masch in forum General Hardware Discussion
    Last Post: 07-30-2004, 09:04 AM
  3. need a extra serial or parallel port?
    By Sway in forum Input Devices
    Last Post: 01-08-2004, 07:48 AM
  4. using parallel port lcd
    By mr0range in forum Software & Software Development
    Last Post: 10-29-2001, 11:30 PM
  5. serial port shutdown signal
    By moahdib in forum Power Supplies
    Last Post: 08-03-2001, 09:52 PM
