They do not need a warmup time. They do need a stabilization period of about a second after they are turned on before they properly generate 120v.
If when you hit the power button, the PC beeps, then the button is fine. You should try to find the manual for the motherboard and figure out the beep codes.
What gauge wire is run to the inverter? If it's less than 8gauge, there may lie your trouble.
KyferEz
LinkBack URL
About LinkBacks
