Results 1 to 5 of 5
Thread: Can someone please open there egg and tell me which way it goes, PLEASE
    Maximum Bitrate clean customs's Avatar
    Jan 2005
    Houston
    I burnt up my power supply, melted all the wires. I am still going to use the egg, and was going to resolder some new wires to the board inside. But I didn't realize there was an input and an ouput size to the egg. Can somone please tell me which way the board sits in so I can install this right. I burnt up everything real bad, but luckily it didn't screw up the screen, but I have to make new wires because there is no more wire that has insulation not melted off. Damn Im glad I didn't burn up the screen.
    Please help me out quick.
    Kenny
    281-451-1529
    krose@rosesofhouston.com
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
    Jan 2005
    Houston
    If anyone has there egg they want to sell, please let me know.
    Kenny
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    The output is where the inductor and 220uF cap closer.
    The input is where the 330 capacitor closer.
    negative (-) for both in and out are solder point closer to the the edge of the board.
    possitive (+) for both in and out are solder point closer to the middle.
    Obviously you can read tell which is + and - base on what printed on the capacitors.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jan 2005
    Houston
    Good point, I think I was a little freaked out that I had burned up my screen to think about it. I tested out the egg, and apparently burnt it up. I ended up running a wire from my PSU to power the screen, and it actually got rid of some waves that was on the screen. Thanks for the help. I still can't believe it melted all the wires and didn't screw up the screen, and the wires that were melted were on the side between the egg and the screen.
    thanks again,
    Kenny
    Quote Originally Posted by MatrixPC
    FLAC Chairboy's Avatar
    Jan 2004
    Why are you using the egg at all? It's much better (brighter picture, easier, etc) to just get 12v from your computer power supply. I think that's what most of us do.
    The egg is sucky, it adds interference sometimes and makes a dimmer picture.
    Chrysler 300 - Fabricating
    http://hallert.net/
