Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: How to build a very simple delayed power oft circuit?
  1. #11
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Yes. OK, better pic...
  2. #12
    I see. So the constant to momentary circuit can have the capacitor and resistor on either side of the relay coil.
    I sense a trip to radio shack tomorrow to buy the pieces for this circuit coming on.
  3. #13
    Mar 2004
    Florence Yall, BFKY
    Right. Plus get another reed relay for the serial port so you can do the fake UPS thing. That might also be done with an opto-isolator but I've never really done that kind of thing yet. I guess there are a few ways to make this all solid-state, but I don't know how a power button works (grounded or +5V?) and serial is definitely +5V. Oh well, someday.
  4. #14
    Sigh. I think my COM port is bust. I get an error when I try set up the UPS. My PS/2 port died a few days ago and I think theCOM port might have died at the same time .
  5. #15
    Mar 2004
    Florence Yall, BFKY
    My condolences on the ports. It's probably not worth trying to fix since it's all tiny SMD parts. You could get a USB-serial adapter though. So far from what I've had (Cypress and Prolific chipsets) the Cypress ones don't have full functionality. Figuring out the chipset before you buy it is the hard part though.
  6. #16
    Since I was intending to use the ps/2 port for a touch pad, I'd end up buying a usb->ps/2 adaptor and a usb->com adaptor. I think the board is still probably under warranty so for postage + the $5 charge I can get it fixed (I had to do that immediately after getting it - so much for it being a very cheap board in the first place!).
  7. #17
    Ah. Pure user error! I still had the ELO touch screen drivers installed using COM1. Hyperterminal gave me a more useful error - that the COM port was actually in use. So I got the fake UPS apparently working (although not yet with any delay) and only have a bust PS/2 port which I can probably live with.
  8. #18
    And I think I found the cause of the bust ps/2 port - I turned the m/b upside down and a screw fell off it from that corner. It must have rolled off the shelf above where I was working .
  9. #19
    Mar 2004
    Florence Yall, BFKY
    LOL I bought a new modem once because I thought it was dead, then realized it was in use the day the new one arrived. TAPI doesn't give any good errors either.
    For delay, you could beg weekendowl to add that as a feature.
  10. #20
    Supposedly with the right warnings set, there'll be a 30 second delay which is ideal for my purposes. But right now it's shutting down as soon as I enable the UPS (nothing yet hooked to the com port).
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  3. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
  4. simple LED circuit.. did i do this right?
    By ShinkunoNamida in forum Off Topic
    Last Post: 06-04-2002, 01:23 AM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
