Page 4 of 4 FirstFirst 1234
Results 31 to 32 of 32
Thread: How to build a very simple delayed power oft circuit?
  1. #31
    Quote Originally Posted by Curiosity
    Also, the relay needs a clamping diode. I found out what that can do if it's not there. When the PC is off and you turn the key off, it closes the relay for about 1 second and starts the PC up. Not good.
    Hmm. I might be able to use that effect to generate a momentary at power off. I see that the capacitor in your circuit can discharge through the other relay thus drawing current through the 'momentary' relay (unless the diode is present) and triggering a 'click'. It's not really a clamping diode as such then.
  2. #32
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    D'Oh! The other relay! Maybe that's where the power was coming from? Well, I did manage to fix it at least.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  2. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
  3. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 02:36 AM
  4. simple LED circuit.. did i do this right?
    By ShinkunoNamida in forum Off Topic
    Last Post: 06-04-2002, 12:23 AM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 05:27 PM
