I was under the impression that even if the
power inverters switch is in the off position it would still draw a certain amount of power. If thats the case I would like to install something to shut the power off to it all together. If thats not the case and I can wire a switch to the power switch on the inverter I'll do that. I tried gaining access to those wires by removing the front plate, but the two outlets and switch is mounted on that plate and there doesn't seem to be much slack. I'm afraid to pull on it because of fear I'm going to damage the unit.
