Results 1 to 10 of 13
Thread: Inverter Switch?
    Mar 2004
    Inverter Switch?
    Ok, I got my inverter in, but how do I tell which is positive and which is negative, if both wires are black. Circles below are the two wires. Got any ideas? Let me know if you need better pictures or other pictures.
    Model: Xentrax XPower 400 Plus
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    IF you're just talking about the two wires that run to the actual power switch on the inveter, there isn't a pos and ground. Th switch interupts the positive wire. So in a sense, both are the positive.
    Of course if you're talking about different wires, then I have no clue.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Both are positive?
    If that's your power switch, it's most likely that the switch is making a contact (it could, alternatively, be breaking a contact, which I think is what Skipjacks was referring to.) In any case, one is positive, one is negative (or else there wont be a current to make/break), but it doesn't matter which is which because contact switches aren't polarity sensitive.
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    As mushin said, the wires for the switch are just closing or completing the path for a low voltage circuit which is used to trigger the inverter to turn on. If you need to connect something specific to the positive side of the switch circuit then you will need a multimeter to determine which one is positive. Let us know what you are trying to accomplish and you may get a better answer.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
    Mar 2004
    Hey good idea. I am trying to add an additional switch, located in my center console. The main idea is that I want to be able to take the inverter out, if the need ever arises, so I want to keep the current switch intack. Is there a way I could test to see what to do? I have a DPDT switch that I want to hook it up to and might have wired it wrong, since I did not have the inverter at the time.
    Anyways, that is what I am trying to do, got any more ideas?
    Mar 2004
    So, any more ideas? Should I just check the voltage of those wires?
    Jun 2004
    Idaho
    Simply connect your external switch directly across the switch in the inverter (parallel). Polarity does not matter in this case. Then when either switch is closed the inverter will power up. Use a connector in your wiring to be able to remove your inverter as needed.
    Rick S.
    Mar 2004
    yea, that was my original option, but was not sure if it would work. I know that the relay would work.
    Mar 2004
    Ok, got the relay working just fine. Now I am having problems extending the LED's. I want to leave the factory leds, but just use some wire to extend them. Would I need to extend both + & - or could I just extend the + and ground the LED elsewhere? What would you call that, parallel or what?
    Would i need any resistors?
    Low Bitrate Twopoint's Avatar
    Jul 2004
    Kitsap WA USA
    run both wires,the ground on the circuit may not be the same as the car
    '95 2 door Yukon
    in dash Xenarc 700TSV
    /w HP laptop
    into (installed)
    HU Alpine 9827 \ AMPS MRD-F540 + M301
    MB Quart 216\213 + DVC 10 Sub
    CarPC Pics
  1. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 02:20 PM
  2. Power inverter on/off switch question
    By Skipjacks in forum Power Supplies
    Last Post: 01-22-2005, 12:33 PM
  3. Replies: 13
    Last Post: 09-20-2004, 06:01 PM
  4. Help needed on switch install for Inverter
    By eazyrog in forum Power Supplies
    Last Post: 07-24-2004, 06:42 AM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
