Results 1 to 7 of 7
Thread: Help!! OPUS not powering
    Low Bitrate Mush's Avatar
    Dec 2004
    UK
    Hi
    I started installing my Carputer this morning, everything went fine. Installed everything and it booted up the first time round (whithot the screen).
    Now when i Unpluged the Psu (opus 150w) to repositon the pc case in my dash the pc failed to boot. T
    the opus is now flasing twice. When i conected the opus the first time i didnt conect the Ps j9 from the opus to the motherboard but used a switch insted and that seemed to work but now nothing seems to be working.
    Ive double checked all the wiring and the motherboard but still no luck
    Please help.
    Dec 2004
    UK
    hi??
    Oct 2004
    Massachusetts
    turn j9 around and try again, two flashes should mean that the boot failed because of
    1. j9 is installed backwards
    2. Motherboard BIOS settings are incorrect
    3. Software crash
    4. bad PS
    My money's on #1 since your switch method worked
    Dec 2004
    UK
    thanks
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    Does the toilet smilie mean that you figured it out?
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
    Constant Bitrate StationRocket's Avatar
    Sep 2003
    Rochester, NY
    do yo have your car running when you are doing these tests. Sometimes mine won't start if the 12v acc line's voltage is not high enough. This results in the PC not starting if i just flip the ingition to ACC and not actually start the car.
    Jun 2004
    AZ
    Ive got the same problem. Worked fine last night but now will not power. My green wire on the 20 pin connector is giving me a 5 volt reading. This is very odd because my key is not in the ignition. It should only have power to it when the 12v on wire has been turned on by my key at the ignition. Help?
  1. Opus not powering on VGA/Sound
    By TheGeneral in forum Power Supplies
    Last Post: 10-04-2004, 01:01 PM
  2. powering LCD off my opus
    By beaverpants in forum Power Supplies
    Last Post: 07-13-2004, 05:28 AM
  3. Relays & Powering Opus
    By [iG] in forum Power Supplies
    Last Post: 06-19-2004, 10:02 AM
  4. Opus 150 and PW-70a powering one carputer
    By Altimat in forum Power Supplies
    Last Post: 05-19-2004, 11:43 AM
  5. Strange problem powering xenarc from 90w Opus :(
    By Brettster in forum LCD/Display
    Last Post: 05-11-2004, 05:19 AM
