Results 1 to 3 of 3
Thread: need help choosing
    Dec 2004
    Howell, NJ
    need help choosing
    for my car pc i plan to run a microATX board and processor i have lying around. the board is a ECS K7VZM and has a amd 1ghz processor in it (i forget exactly which model). also in this setup i plan to run a fairly big full size hd (200gb or so), a agp video card and some kind of sound card (not sure of internal or external yet). it currently has 256mb or memory (2 128mb chips). what i would like help with is powering it. i figure i will have to use an inverter but was wondering if any of the dc-dc power supplies would work for me. any suggestions would be helpful.
    2003 Steel Blue PT Cruiser GT Autostick, Mopar BOV, K&N FIPK, Dual Exhaust, Boost Gauge.
    ICE: 2 12" Infinity 1230W, JBL BP1200.1, Infinity 6000CS, JBL P80.4, Sirius Starmate.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    i take it you have heard of Opus?
    M1 ATX work but with AGP graphics and 3.5" HDD no point messing around. Go and do a power budget (search for power calcualtor for links) for your system and see what power you are likely to need.
    If you use an inverter, you should check out the CarPC EZ or Pro Power Controller for turning on and off the inverter, pc, and more.
    As for the power calculator, I have one on my website Goto the tools menu bar item, then select Power Supply Calculator.
    KyferEz - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
  1. Help needed choosing software
    By sremick in forum GPS
    Last Post: 10-26-2004, 11:37 AM
  2. choosing gps, need help...
    By icet in forum GPS
    Last Post: 10-21-2004, 09:11 PM
  3. need help choosing better touch LCD,
    By sr_ryan1 in forum LCD/Display
    Last Post: 09-27-2004, 05:34 PM
  4. Choosing a Character display...
    By Kryten in forum LCD/Display
    Last Post: 10-16-2003, 10:43 PM
  5. Help choosing visors/LCDs
    By quinton in forum General Hardware Discussion
    Last Post: 05-22-2003, 06:12 PM
